surveillance system in a garage
flh69
I am new to this forum and I did a search but could not find the answer. I would like to install a surveillance system in an unheated garage. It would be hardwired, monitor not attached. Due to the location of the garage from the house, I would like to keep the dvr in the garage but it is unheated. The temperature ranges in my area from rarely 0˚ to 90˚. Is there any systems capable of working in these temps?
Thanks
dogdog
other than the electrolyte capacitors, Also check your haddrive specifications ..... it might not survive the cold. either that or get one of those extreme mil-spec hard drives that can survive the cold./ heat or a ssd.
Kaizen
New England
I've had a qsee 8 channel one in mine from 0 f to 100 f. did fine. it actually creates heat as all hard drives/electronics do so in winter its ok
Vintage Veloce
San Diego
Get a dropcam. It is spec'd for 0-35 C, so that might not be enough. But if you can keep it above freezing... I have one and it's great. Constantly uploads the video stream to the garage, so matter what happens, you have the video.
F
flh69
I want to thank everyone for their replies.
If the hard drive is where the camers are, then what safety are you getting? The thief will just break or steal the hard drive.
I live in a village & have neighbors right next door. I know what you are saying but I don't live in a high crime area & am more worried about "kids" and dumb a** thieves. If a professional guy wants in, he is probably going to get in & remove everything he wants. I do plan on putting the dvr out of sight. I do have an outside shed that I could possibly run the wires over to & then it would not be in the same shed. To bring the wires up to the house is impractical.
kbs2244
Put the DVR in a cardboard box and the in the bottom drawer of a file cabinet.
Label it "X-mas lights" Maybe even throw a string or two on top.
That will keep it out of sight and a 20 watt bulb on a thermostat will keep it warm.
Chevy-SS
Rhode Island
Once they get INTO my garage......I don't want them to leave.
So video of what happens next, would be a negative.
What, you plan on murdering them?? :scared:
Let's assume we are all going to act responsibly and legally. In that case, video would be your best friend.
SALIV8
chicago and s/w michigan
what about the wires sticking out of the back? its too easy to follow wires to the dvr, when the dvr is in the same room as the cameras. just doesnt make any cents to me, and seems like such a waste of money on a security system.
F
flh69
This is my plan. The dvr will be hidden. Any suggestions on particular decent brands of systems?
F
flh69
I forgot to add the cameras will be outside. So waterproof is needed. Also I want IR cameras.
Stuart in MN
Minneapolis
I would say your money is better spent on things that will keep people out of the garage in the first place - decent locks, strong door jambs, exterior lighting, etc.
Having said that, you can go to the website for most manufacturers and find an owner's manual or a tech spec section that will tell you the recommended operating temperature for the DVR. Typical would be something like 0 to 50 degrees C, or 32 to 122 degrees F. So, you'd want to keep it in an enclosure of some kind with a small heater. Also, the heater will help protect it from condensation. A small light bulb would work as mentioned, but I'd like to see something with a thermostat to turn off the heat if gets too warm (the DVR will generate a certain amount of heat all by itself so you don't need too much.)
LWW
SF Bay
Stuart took the words right out of my mouth. The video surveillance system was the last thing I installed after good auto-locking garage doors, solid door jambs with solid doors and the lock sets screwed into the door and jamb with 3.5" #8 screws and motion sensing flood lights that cover the entire exterior of the house. Because of their proximity, when one turns on, they ALL turn on. THEN I installed a 16 camera surveillance system.
vintagespeed1956
RanchoCucamonger, CA
...neighbors right next door....I do plan on putting the dvr out of sight....bring the wires up to the house is impractical.
my security system is for AFTER something comes up missing, i'm not going to watch the thing all the time. i can only hope to know who to go after if it's ever needed. most systems you can't read license plates so YOU will have to identify the thieves most likely.
as for bringing wires to the house, if you use IP cameras you can setup a simple wireless bridge to the house (2 wireless APs for the bridge and a POE switch (FS108PEv3 works well!) to power the cams) and keep the DVR hidden in the house where it should be.
how do you prevent power from being shutoff to the garage? thinking about a small UPS to power the garage system in that event?
Gear Wolf
You could always try the NEST drop cameras. They have a very wide viewing angle and you can access their footage online without needing central hub. The best part is, you can download the footage and view it pretty much any time you want.
excavator
The security cameras not only help solve a crime after the fact but help on the days before the crime took place. You sometimes catch crooks checking out things on your site well before they strike. At my business location I have several cams including a licence plate capture camera. Three years ago a murder took place on my location right in front of my security sign warning. The next day the guy was found and arrested thanks to my cams
DonPowers
On The Hair At The End Of The Dog's Tail
I'm reposting what I said in a couple previous security threads.
Like others have said, you are not going to stop a determined / experienced thief but you can make it easier for law enforcement to catch them.
On my garage, I put in a commercial steel entry door & frame with commercial grade lockset & deadbolt. Windows are 15 ft above grade and the overhead doors are insulated metal. If someone wants in, they can just ram the overhead doors. My cameras however, should catch the action.
Motion sensing lights make a good deterrent at night. Motion lights with built in camera are even better. A friend, who got robbed when away, after the incident, put up motion sensing lights with the built in cam. He found a few occasions, when checking the cards, of people setting off the light and running away. There are several brands out there, just go with the higher resolution cams.
I prefer the bird house or other covert type cameras. Reason is, a guy that I know who has a junk yard told me the culprits wear hoodies or ski mask and show up on cam but can't ID them. He has since removed all of his camera warning signs and has hidden his cams.
My neighbor is a retired State Trooper and told me they have a very good idea of who the local hooligans are. They just need enough evidence to tie them to the crime.
Set up a camera or two for photographing vehicles. A time stamped photo or video of someone in a hoodie may not be enough for probable cause but along with time stamped vehicle photos or video, they may have a better chance of bringing someone in for questioning. The more evidence the better.
We had a suspicious vehicle cruising the road last summer. Pulled clips of the vehicle from game cam and surveillance cam then neighbor distributed to State Police, Local Police & Sheriff. The vehicle had been reported before. With the photos, they were found and confronted by the Sheriff. They were from away and running scams in the area. Haven't seen them since.
Then you always have the big bad dog option.
mirachal
According to your requirement i would suggest you to choose Wetter Solutions . They provide best and affordable security camera service with complete installation setup. They delivers he service of Security Cameras Installation in Orlando.
matt_i
I think if you built a simple insulated enclosure for the hard drive, lets say 1" foamboard for now, and either made a removable lid or removable ends you could simply put the cover(s) on in the fall and take them off in the spring. I think as mentioned earlier the electronics are their own heater, you just need to capture it/slow its loss during the winter.
steveo1o9
Eastern MD
First post is to bump a 2 year old thread to endorse a specific company? Sounds like a spammer...:headscrat
jfitz
Eastern Ontario, Canada
I have a NAS (network attached storage) which has dual hard drives. It acts as a mini server with its own operating system. I use it to backup my computers for home/work and can access it from anywhere. It also came with 4 camera licenses and surveillance software. I use a combination or outdoor/inside cameras from Foscam connected wireless to my router, cameras set for motion and then record for 2 min. You can also view remotely with an app on your phone. Works good. Cost about $1k
sjuhawks19
I just put a Ring floodlight cam on my garage. It's hardwired in and up high enough that they can't reach it without a ladder. Also it looks like a motion activated floodlight, most people don't realize there is a high res camera included. It connects to your home network over wifi and sends you alerts on your phone when someone/something is there (which is customizable). $30 a year gets your 60 day video cloud storage too. If you buy other Ring products they can all be on the same network and linked together.
