christian said:Why would you use osb instead of the normal tiles?
christian said:Oh. What ceiling do you have in there now? Or do you just have exposed joists? Is drywall not an option?
autoist said:Here's one: From Lowe's - runners attach directly to rafters.....no problems so far & its been a summer & this winter.
autoist said:Got it all right off the shelf..panels are standard 2x4 Armstrong's...runners are all plastic & screw right to rafters...right now, I've got about 20x34 done & am getting ready to do another 20x44...the part I've done so far cost around $700.
toolman said:Normal tiles will sag over time from the humidity. But the main reason is when you open your overhead door and its windy out it blows the tiles upward. Buy using OSB there is enough weight that this doesn’t happing.
