stickshift
I'm swaging aluminum ferrules onto 3/16" 7x19 wire rope. Ferrules I'm using.
Per these instructions at US Rigging Supply, 3/16" aluminum sleeves should be crimped 4x and the maximum after-swage dimension should be 0.475". I borrowed a friend's swager (looks to be a $20 18" swager found at big box stores) and the swages are measuring 0.480 - 0.485". I don't have a go/no-go gauge, so I'm using digital calipers, and I assume the correct place to measure is across the widest part of the crimp?
US Rigging's 0.475" after-swage dimension is supposed to yield 90% of the breaking strength of the wire rope. The 3/16" wire rope itself has a working load limit of 840lbs (which itself I assume is some fraction of the breaking strength). I'll be using loads of less than 200lbs. Any thoughts on whether being 0.01" over spec is good enough?
The swager looks pretty old and had some rust on it, so I assume it's been worn down a bit. If I buy a new swager, can I re-swage these ferrules to try to get down to spec, or should I start over with fresh ferrules?
