YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 502
Has anyone ever done themselves or seen reports of people swapping out the gears in their impact wrenches? Especially in right angle impact wrenches, gears are used plenty.
I was thinking that a small gear with less teeth driving a larger gear with more more teeth will produce more torque.
Now we can't simply swap out gears with different sizes gears without engineering different mount locations or possibly different sizes cases to accommodate changes in gear sizes at different locations.
But you can keep the same sized gears and instead go to gears with a finer pitch resulting in more teeth.
But if you increase the number of teeth in the drive gear and driven gear but keep the same diameter by changing the pitch, does the gear ratio remain the same? If so this would be kind of pointless as no more torque or speed would be obtained.
