Switch Help
mjb
San Diego
I am looking for a push button switch where the button is recessed in a 1 inch diameter hole, but have had no luck. I probably am not using the correct terminology.
The switch is housed in a 2x3 inch plastic box about 1-1/2 inches thick. It is used to open an electric door strike and must be recessed so nothing can accidentally trigger it.
I would have taken a photo, but it was thrown away. :evil:
Any help would be appreciated.
frankush
IL
It's a control pushbutton. Square D, GE, Allen Bradley all make them. Push button, contact block and guard are all seperate items. Momentary contact. Go to your local supply house. Extended guard might have to be ordered, but just screws on.
mjb
San Diego
Thanks for the responses. It is called a hold up/panic alarm switch.
Here is a pic
Thanks again!
Norcal
That type of switch should be avail. at a vendor selling alarm materials.
Worsedog
Central FL
Here is a pic
Thanks again!
The problem with most of these "hold up" switches is that when you push the button it latches in the on position. They usually come with a little metal tool to pull the plunger back up after the incident.
BFBOB
Alarm - holdup buttons. Also available in momentary, look nearly identical to pix in the previous post. I'm in the biz. I'll mail you one for 10bux.
