A couple of things come to mind.
The copper question is a big issue, and the conclusion "ask the gas company" is always the right answer. Some gas companies do not allow it due to concerns with sulphides in the gas stream that could lead to corrosion of copper.
The water heater can be converted. The manufacturer may prohibit it though. It's a sticky situation. If it was mine, I'd convert it regardless...but I cannot recommend that you convert yours. Contacting the manufacturer to see if they have a conversion kit is the place to start.
The thing about propane vs. gas and which one is "hotter" still baffles me. A BTU is a BTU. If you burn 30,000 BTU's per hour of propane or 30,000 BTU's per hour of natural gas...it's the same "hotness". There is no "one is better than the other".
On price, around here natural is running about 70 cents per therm retail. That's in the ballpark of $0.63/gallon propane. In the 20 years plus I've been around it, natural gas has never been more expensive than propane to homeowners. There have been a couple of times (like 2000 for instance) when some large commercial users were able to negotiate propane prices lower than natural gas...but it was short-lived.
On the fireplace...if it uses ventless logs it probably CANNOT be converted. You'll need a new burner assembly.
One more thing you may need to look into is dealing with the switchover given how much fuel you have in your propane tank. Sometimes propane companies will buy it back, but often not. So....you'll need to time this to use all you can rather than give it away.
Good Luck!
Phil
According to my natural gas company, copper is ok.
I contacted Bradford-White, the manufacturer of my water heater, and they do sell a kit to convert it. Of course, the kit is $350 from them. I did find one place online that is selling it for $260. Seems crazy expensive, now I'm debating buying the kit and doing it myself, or calling in a plumber or hvac guy.
My propane tank is leased, so since I don't own the tank, I've checked and they will buy back the propane left in the tank when they pick it up. That said, it currently has a little less than 50% in it, so I'm good until winter.
WE Energies, the natural gas company, will be installing the meter up to my house. According to them, it is up to my "contractor" to hook the meter up to the house and turn it on. So I'm looking at:
1. Disconnecting the propane from the house
2. Run new plumbing in the house that accomodates my BTU load and natural gas.
3. Convert my furnace, water heater, and boiler
4. Hook the natural gas meter up to my house.
All of which I'd like done in the same day so I can have hot water every morning! Who is the best to have do this? HVAC contractor or plumber?
