This is probably a stupid question, but I'd rather be safe than sorry.
I have an overhead fluorescent light fixture that uses two T8 bulbs. It has a sticker that reads (I'm typing exactly what I'm reading):
CAUTION: RISK OF FIRE USE ONLY
2xT8/32W MAX.G13 FLUORESCENT LAMPS
BALLAST RATING: 120V 1.0A 2x32W 60HZ
TO GET BEST PERFORMANCE OF LIGHTING, SELECT
10,000 HOURS LIFE BULB WITH CRI OF 80 OR HIGHER
The bulbs read as 32W, 3500k (based on the printing on the side).
Now, the other day I saw some LED "shop light" bulbs at Costco that seemed like they might be the right size. Pretty sure this is them:
http://www2.costco.com/Browse/Produ...3&topnav=..&cat=99288&Browse=1&hierPath=95905
I have three concerns:
1. Is there any problem switching out fluorescent with LED bulbs in that fixture? I've replaced regular bulbs around the house with LEDs and CFLs before, but I don't know if fluorescent light fixtures work any different.
2. The sticker on the fixture read 32W, but the lights at Costco read 38W of input power, which seems kind of high for LEDs, so I'm not sure if it's referring to 38W "equivalent" or if it actually is drawing 38W. If it's the latter, then is it safe to say that I could NOT use the LED bulbs, because the fixture wouldn't have enough power for them?
3. I assumed that LEDs were ALWAYS more power-efficient than any other type of bulb. The lights I'm looking to replace are always on - 24x7, so my hope was to help reduce power usage/cost by switching to LED. But if the old bulbs are only drawing 32W, and the LED draws 38W, then that seems like it would be a stupid and LESS-cost-effective switch. Or am I missing something?
[EDIT]
The more I'm looking at the difference between LED and fluorescent bulbs, it almost seems like fluorescent is better than LED in terms of:
1. Bulb cost
2. Lumens
3. Wattage
So is there ANY advantage to switching to LED that I'm not seeing? The LEDs vs. regular lamp bulbs seemed like such a huge improvement in terms of power savings that I figured the same would apply to fluorescent bulbs, but I'm wondering now if that was a bad assumption...
[EDIT]
1. Bulb cost
2. Lumens
3. Wattage
