Swivel socket storage ideas
m_hatcher
I am trying to find a good way to store my 3/8" swivel socket set in my toolbox. At the moment I have them on rails and they just lay down in the drawer, but I would like to find some other way such as a mechanics time saver tray etc. Just looking for any input and pics of how you guys store yours.
I have several sets, and so far, the best storage is the SK set that came in a metal box.
Another option I'm considering is to drill a wood block with exact (loose) fits for the others so they are held dead vertical instead of flopping like they do on the ones I store on rails. You can actually drill the holes slightly overlapped so the "holes" connect somewhat and have a scalloped look.
Link-Belt
Arlington Texas
I just took the harbor freight Hanson knock off tray and cut the stubs off were the plastic square is left and put them on that. My box is stationary though I don't know how it will work if I was mining my box.
RKA
Another vote for the VIM mag rail TL (newer one). Only issue is if you like to pick it up and take the whole rack with you...you'll need two hands and possibly a screwdriver to pry that magnetic rail off the floor of your drawer! So no, the rails aren't going to tip over! I just leave the rails in place and grab the size(s) I need.
wanted01
I'm a mechanic by trade, and found that with all the comercial socket rails, they take up too much room and are quite often a pain to use. I solved this by taking a scrap sheet of 5/8" plywood, placing all my sockets on it and used a pencil to mark where I wanted them to be ... Ie: from from to rear, 1/4" then 3/8" then 1/2" shallow, then repeated for deep sockets. Aster I had them layed out, I drilled the appropriate holes to accommodate dowel that I tapped into the holes. I did not still all the way through, and did not glue the dowel incase I wanted to change the dowel out if it got oil soaked and swollen. The dowel was cut off to extend about 1/2" above the board, and I used a sander to put a chamfer on the top of the dowel to make dropping the socket on easier. The result is a socket board that holds all my sockets, takes up half the room that the commercial rails did, and the sockets take zero effort to remove and drop on, but even the tallest of sockets will not tip even if you shake the drawer!
beelsr
NE PA, USA
I'm a mechanic by trade, and found that with all the comercial socket rails, they take up too much room and are quite often a pain to use. I solved this by ...
1. welcome to the board, you sound like a good addition. :beer:
2. even with that excellent description, you are going to get bombarded for pictures! :eyecrazy:
jjjrmx5
Cincinnati, OH
In my area , we call those Amish Hansen racks.
LOL.
And socket rails take up too much room? I think you need to go back and do the math on that one because you are sadly incorrect. And I bet your HS math teacher will agree.
If not in their vac-formed tray, swivels are best on a rail I have found.
Flop or not, it's their nature.
wanted01
jetmech09
Use a rail. Put o-rings on the joint. Now they should stand up moderately straight...kind of like a drunk socket.
csmitty
Mine are in the bottom left. Gearwrench 3/8s are on the rails they came with and not bad. My 1/4s are on a twist lock rail. Gonna split those up though.
srmofo
SW ohio
heres how I did mine
I used a piece of the fake wood used for decking. I found a 16' piece clearanced out at Home Depot for $16. IIRC normal price for this particular brand was around $48. 1 side is smooth and the other has wood grain. The cheaper stuff has deep grooves cut on one side, not good for socket holders.It was pretty quick and easl also because all of the swivel sockets have the same diameter base compared to the Torx sockets
On my first one I spaced them out, but didnt like how much room it took up so I redid it and got a bunch of other sockets on it also.
beelsr
NE PA, USA
I like using wood because you can mark it all up to make the cuts/holes and then just run it through the planer at the end to clean it all up.
lines, what lines? i did it all freehand, baby! :bounce:
what's tedious though, is drilling 100+ 1/4"-ish holes for bit drivers into a block of wood. had to stop a few times and do something else for a while...
