Synthetic in OLD compressors
Ramper
Southern MN
Is there any issue in running synthetic compressor oil in OLD compressors? I know that some people say you should not run synthetic in old small engines because of seal issues, but waht about compressors?
djkeev
North Western New Jersey
Not running synthetic on an older car was a Very early problem in the industry. Today, those problems are solved and there are no worries.
Compressor oil? I don't know but imagine the same technological advancements apply to those oils as well.
Dave
pfbz
My backup cheapo HF compressor used to trip the thermal breaker and shut off for a while if I used it for a continuous application. Changed it to synthetic, and now it will run as long as I need it without stopping, so it is obviously running much cooler.
Some manufactures like redline and amsoil make specific single weight non detergent synthetic compressor oil, which would be the best choice. I've used standard synthetic automotive oil (mobil 1) without issue though.
Not really addressing your question directly, but I now run synthetic in all my compressors.
The issue with any "engine" that runs without an active filtration system is suspended particles. The detergent keeps them in suspension so the filters can take them out. Without a filter that stuff is potentially getting where you don't want it. With non detergent it will settle out and form the infamous layer of crud on the bottom of the compressor case, which also keeps it out of the sensitive areas...
buening
Decatur, IL
I agree with Outlaw, only non-detergent oil gets put in my compressor. I also use non-detergent oil on my old Kohler powered John Deere lawn tractor, as it too is splash lubricated without an oil filter.
KinzeMech
i agree with outlaw, only non-detergent oil gets put in my compressor. I also use non-detergent oil on my old kohler powered john deere lawn tractor, as it too is splash lubricated without an oil filter.
317?
pipsters
USA
The OP is asking about synthetic compressor oil, which I would assume is not the same thing as synthetic motor oil.
Worst you could do is run it, if the seals start to weep replace them, they needed it anyway :).
chris142
apple valley,ca
Cars use a pressurized oil system so there's a better chance of a leak vs an old splash lubed compressor. Syn should be fine in an older compresser.
KinzeMech
I was going to ask how it was running if it was a 317. Used to have one, it was a kohler, splash lube, but with opposing cylinders. The uphill one always starved of oil if you mowed on a sidehill.
bsaint
Manchester, CT
I was told by an experience air compressor tech that synthetic oil influences the seal between the rings and the cylinder adversely.
It should only be ran after the compressor has been deemed "broken in." After that its fine.
Hetman
It influences them very good :E . Mineral oil, on the opposite, can make them seize faster - I mean all the cheap, poor quality that is sold nowadays.
