timewarp
I have quite a few 3' T-12 single light fixtures that I am changing out the ballasts to T-8 and replacing the bulbs, the ballasts I have found the most reasonable cost wise will work for 1 or 2 bulbs, many of my light fixtures are mounted in pairs about 1' apart (parrallel to each other not end to end). Now here's my question, instead of putting 2 separate ballasts and only hooking 1 bulb to each, would it be ok to use one ballast in one fixture and run the output for the other bulb to the other fixture thru the existing 12/2 wgrd nm wiring? If not thru the nm, what about if I ran EMT between the fixtures to run the wires from the ballast thru?
Thanks in advance for any assistance.
