T/G Router bits 5/32
Certified Drunk
Seattle, WA
Anyone know where I can get a T/G router bit for some 7/16" think cedar. The tongue is about 5/32.
Custom Router bits are $$$
I'm going to install new soffit's on the house and want to end finish the boards.
Thanks
Zeke
You would do well with a dado blade and a slot cutter both of which can be used on future work as opposed to a dedicated bit set. Actually you don't NEED the dado as you could use the slot cutter or circular saw to cut the cheek. Or you can spline them using only one setup using the slot cutter.
Zeke
