T Handle or Screwdriver Torx?
nezzman
I am looking to buy a torx set for general use. Car repairs, home repairs….
I already have sockets, and l keys, but sometimes the hole leading to the bolt is too narrow to let me in with sockets, and the l keys are pretty short.
Question is, am I better with screwdriver handles, or t handles?
Cheers
Aaron_W
Both?
I don't actually use Torx much, and have been served just fine with one of those screwdriver handle sets that includes a variety of replicable tips providing Torx, Allen, Phillips etc. I do like my T handle Allen Wrenches though and prefer them over the multi-holder (Swiss Army Knife style), L keys or multibit screw driver if I'm doing more than just one or 2 screws. Then again I am quite happy with a regular screw driver for Phillips or slotted screws...
Sorry probably not much help.
N
nezzman
I was leaning towards the screwdriver style. Anything large, I will use a socket.
The majority of torx I come across are things like interior trim screws, or fixing my washing machine, the screws where all torx.
I would guess a set up to t25 would do ok.
JradM
Alberta
I like the screwdriver style for most things. I have both though and enjoy using T-handles. I think your instincts are probably right.
Dave455
Sussex, England
Depends on the size.
Smaller sizes - T10, 15, 20, 25 for sure, definitely go with screwdriver handles.
Bigger sizes, it’s nice to have the leverage of T handles, but I have both, with a fair degree of overlap!
f121
UK
Screwdrivers. Typically if the fastener is big enough to need more leverage, the hole is big enough for a bit on a ratchet
Tools4Me
Bits will always be more flexible than screwdrivers or t-handles if you can get yourself away from premade bit sockets (especially for work in tighter areas), but I also understand the issue of insert bit sockets not working for anything recessed. Most of the time, I get around that issue by using power bits instead of insert bits. Hex power bits are very common in 2" and 3" (or longer) lengths and the shaft is usually also narrowed for at least an inch, so they will work with most recessed fasteners.
If you want to use longer power bits in a regular insert bit socket or insert bit handle, use a metal cutoff wheel in an angle grinder to cut off the base of the bit (cut where shown in my attached pic). I have full sets of regular and modified power bits in my tool drawer for ultimate flexibility. If you really want shaft length, think about buying 4-6" long power bits with fully narrowed shanks instead of buying additional screwdrivers or t-handles. If you don't want to modify any power bits, buy a bit handle that is designed to hold power bits (non-ratcheting Malco Connext bit handles are great).
A much more flexible setup overall.
N
nezzman
I might just buy both and see what I like best. I will buy the drivers in the smaller sizes, and a full set of t handles.
cheers
Alpine4x4
Central, WA
Both. I use the screwdrivers a lot, but ran into instances where the torque on the T-handle would be nice and I feel I get much better engagement with T-handles vs sockets so I got the T-Handle Torx as well. Like you said, some areas require the thin shank of the driver to get into and most Torx socket sets have a short bit so they wont work. T-Handle and Screwdriver fit the bill.
Bubba Fett
Eastern NC
You can use longer power bits and a collet-style drive handle, like the Malco Connext or something similar. This is a good choice for a portable kit, and more or less unlimited bit selection.
Ronson25
I use both but prefer my bit sockets over them... Id probably get screwdrivers first tho if i had to start over
