Let's do more lighting work.
My original plan was a strip of wood on the ceiling with led spotlights, for bench lighting.
Only problem was that the wood strip would block access to the top shelf.
So I ordered a 230v led strip with 120leds/5w per meter. and installed it to the bottom of the top shelf.
I don't get it how they do it in China. 12meters of ledstrip costs 24$ shipped to me
It could be a little brighter but it's okay. Very nice for romantic purposes
I saved this aluminium profile from going to garbage. Yes I am a hoarder, but only for the good stuff
I did some corners and holes for mounting. I found this W.A.Whitney corp. punch kit from a yard sale. Full set with the case and dies 10$. Made in Rockford, Illinois USA. Great stuff
I tested two different styles for mounting the strip on the profile. Ledstrip towards to the pegboard and then to the bench.
Led strip has a 30 degree beam. There was not much difference so I chose the easy way.
I made a bunch of small wooden blocks to help the gluing process. I used Loctite superglue. It's supposed to hold up to 120C. I glued the strip about 4" spacing an placed a wooden block to hold it tight. Removed blocks next day.
Mounted a desk light in the electronics/"command center" area. I'm going to buy one of those magnifying led light there.
I bought some machine lights couple years ago for my machining tools. From a local craigslist. I mounted one for the workbench.
It has 24volt H3 automotive light bulb. I didn't have any transformers for 24volt so I replaced it with 12volt bulb. I think I will buy a led bulb for it.
The lamp has 1meter travel and five pivoting points. So it's pretty versatile.
Tool area and the "command center" is starting to look pretty nice. There is still lot to do and organize
I ordered one of these large 15$ mouse pad for test. I think I'm going to order couple more. Very good for protecting the countertop.
I was looking for cutting mat but they were pretty expensive and 45cm x 60cm was the largest size I found.
The mouse bad is 4mm thick, size is 40cm x 90cm. And it has protective film for liquids. (and instructions how to build a gun)
Happy Fourth of July everybody
Shop tour movie
