I recently bought a fully restored USA Made Craftsman 8" Rotary Indexing Table (nearly the same as the Palmgren Rotary Cross Slide Vise) for use on my drill press. I am now trying to find T-Slot nuts for the table but cannot seem to find the correct size. I have checked both Gibraltar and Jergens, but neither makes the correct size as far as I can tell. The height of B is where I am getting into trouble. The ones that I have found are all 11/32" (when they match the other parameters) which is too thick.
Anyone know where I might find 4 T-Slot nuts that will fit this device?
Yes, I know that I can get away with using standard bolts, but if I can find T-Slot nuts I would greatly prefer them to enhance accuracy. If I have to resort to using plain bolts I will do so if I can't find these.
Also, the folks at Jergens recommended that I don't just mill these to fit. They are hardened steel which would make that difficult, and grinding or milling would also remove the black oxide layer.
Thanks.
Here are the measurements that I am looking for (my quick drawing below is not to scale):
A = 1"
B = 1/4" - 9/32"
C = 5/8"
E = 5/8"
Thanks.
A = 1"
B = 1/4" - 9/32"
C = 5/8"
E = 5/8"
