T-Stat for 5kW Heater?
MNMuskie
I have an electric heater (17,065 btu, 240v, 21 Amps, 5000w) that keeps my garage at 50F on its lowest setting. I'd like to be able to lower the temp a little bit, about to 40-45F, as well as have easier access to change the temp. Now the built-in t-stat, on face of unit, is 7ft off the floor.
I'm not very knowledgeable on this subject and have searched around to no avail. Can anyone direct me to a wall mounted thermostat that would work with this application? I've seen circular style thermostats on other hanging electric heaters. Is that something that would work here?
airwalk
Lloydminster, SK, Canada
You could also purchase a minimum 22A relay with a 24v transformer, and then you can use basically any thermostat you would use in your house. I'm sorry I don't know of any distributors for this though.
