T12 still around ?
yeldogt
Went to HD yesterday -- was surprised they still sold the 8' T12 fixtures. Thought they were going away? Gone actually
My one utility building uses only them... still think they give nice light. Twin strips of double tubes. I also have them in one of my studios for general.
Bert_
NW Iowa
There is no general ban on all T12's, Just a minimum efficacy with some exemptions for high CRI. There are also efficiency requirements for ballasts. None of the magnetic ballasts meets the requirements so any new fixture will be electronic.
As far as why you can still find new fixtures, that's a good question. Those new fixtures are cheap junk. I guess some people must be buying them just because it's the cheapest thing on the self.
Y
yeldogt
They looked the same -- quality wise vs every other typical strip fixture. Have no idea about the ballast. They were not very expensive -- but then you have to buy the bulbs.
The last time I bought bulbs -- 8' .. I got a case.
Bert_
NW Iowa
They have crappy ballasts that underdrive the lamps. A full power F96T12 should run at 75 watts, some of the cheap ballasts only deliver 50-60 watts.
Makes it dimmer and if the power is to low the lamps won't last very long.
There are some good lamps still available, last ones I got were Sylvania F96T12/941. >90CRI and 6000 lumens. About $5 a lamp but a huge improvement over the cheaper lamps.
Norcal
A standard F96T12 slimline today is 60 watts, the former 75 watt standard is tagged for cold temps, same thing happened to the F96T12/HO, 110 watt lamp marked for cold temps, former Supersaver, Wattmiser, Economiser, 95 watt lamp is the standard. Which occurred with the energy conservation act of 1992.
Still run F96T12/HO lamps in my shop, & bought a case of 110W lamps years ago, still unopened.
Bert_
NW Iowa
Your right the energy savers are the standard lamp, but lets be honest, they aren't good. Performance below 65-70* is bad, they are hard on ballasts, and usually they are dimmer.
I've always bought the full power ones because of superior performance.
75W slimlines were hard to get for a while but now they seem more common, the triphospor ones I mentioned above are good and every bit as bright as a T8. I know the 95W HO's exist but I don't think I have ever seen one.
American Locomotive
Rhode Island
The 60 watt F96T12 lamps are garbage, and hardly work even in air conditioned rooms. The full power lamps are far superior. We still have a bunch of T12 stuff in the back workshop of our barn. We don't use the area enough to warrant replacing the lights, so we just put full power high CRI bulbs in them instead.
