T12 to led retrofit
bochnak
Mt. Prospect, IL
I have two 4 bulb T12 fixtures (got for FREE) that I want to hang. I could hang as is, however they are not as bright as my current T8's, which only have 2 bulbs and a nice shiny reflector.
I'm thinking of retrofitting 2 LED tubes per fixture. Anybody done something similar? Tubes that you would recommend?
3PKC7tqF5psTTEsYDH0fj38v1HPeAW4qDdoaxIm1_2Q=w800-h450-no
cybrdyke
USA
You have 2 options to retrofit those.
1. Bypass the ballast, bring the black & white down to the sockets to make them hot. Install new bypass-type LED tubes. You can get them at a local electrical supply house or online. Most of these will be brands you never heard of before.
2. Replace the ballast with a new T8 ballast and install new ballast-ready type LED tubes. You can also get those at a local electrical supply house or online. Name brand manufacturers include Philips, Cree, GE.
Good luck
CD
cybrdyke
USA
You can get T8 lamps that are a little brighter than normal T8 lamps, if you want. Look for a 3000 or 3100 lumen lamp. It will work on the same ballasts.
bochnak
Mt. Prospect, IL
Yes, I will look into that. I bought units with .88 ballast factor. I could have payed double for 1.18 factor, which increases output.
cybrdyke
USA
.88 is standard for ballast factor. Couple those ballasts with the 3000 lumen T8 lamp and you've got a really nice, efficient system.
1.18 ballasts are normally used for really high ceilings or places with too few fixtures.
CD
