Not enough light to use the 5000k bulbs. You need to determine the total light you plan to have in your space in lumens and convert it to lux. Take the lux you expect and compare it to the Kruithof curve. That will give you a range of color temperature to use for best results.
Edit - My garage is around 580sqft. I have six 2-lamp T8 fixtures. The greatest possible lumens I can have is 2900 lumens x 12 lamps (bulbs), or 34800 lumens. Convert that and I have 645.8346 lux. Another option is to multiply lamp lumens by total lamps and divide by sqft to get foot candles. LLxTL/SQFT = FC Then you can use this link to find lux.
http://www.rapidtables.com/calc/light/fc-to-lux-calculator.htm
Based on the Kruithof Curve I need lamps in the 4100K range to keep them from looking yellow or blue. The problem is fluorescent tubes are omni-directional so the thing to remember is that max lumens is nowhere near what you'll actually get on the ground. I like to cut whatever the bulbs nominal lumen rating is by at least 30% or more depending on your fixture type.
https://upload.wikimedia.org/wikipe...of_curve_2.svg/978px-Kruithof_curve_2.svg.png
Using 35% I'm down to 39FC, or 419.792 lux. Based on that, 3500K lamps are the way to go for a pleasing, clean white look. 4100K will tend to have a blue shift and 3000K a yellow (jaundice looking) shift. If I use lower wattage bulbs with 2400 nominal lumens, I could almost drop to 3000K lamps for a more relaxing, warm feel which I prefer for working at night without the light looking yellow.
All said, it depends on how many foot candles you want or need. Link below is for recommended levels, but 20-30FC is good for puttering around in the garage with additional task lighting available.
http://www.bristolite.com/Interfaces/media/Footcandle Recommendations by IES.pdf
Note: I like 800 series Osram Sylvania and Phillips lamps, but am going to try TCP since they are cheap.
