jumpstart
I've got a Delta table saw I set up a few weeks ago. Been new in the crate for years in a heated basement. Never been used before.
I set it up and started using it to finish the trim on the shop windows. After only maybe a dozen cuts, I noticed it slowed down, then tripped the breaker.
20amp so I know the circuit is sufficient. I tried using an outlet on a different circuit. Same thing. It starts and runs at a slower speed then trips the breaker. Regular breakers in the panel, not gfcis.
So basically brand new motor. There are 2 capacitors on the outside of the motor. Should I just replace those and see what happens? I don't really know much about electric motor diag.
