Sticks McGee
Hey everyone I have a question.
Currently I own an older Grizzly contractor saw (I believe it's a 1023). Love the saw as it is cast iron with cast iron wings (heavy sumbitch). I also have a dewalt router mounted under a router table that I built years ago. The table saw does not have a mobile base and I am extremely limited in space. The router tale top is a piece of laminate I got for free years ago. It is about 30" deep by 50" wide and about 2" thick (again heavy). I built a basic 2x4 frame to attach the top to. I built a home made fence for it that I simply clamp in place on the table top. Right now the space in my garage does not allow me to set either the router table or the table saw out in a useable spot so when I do work on a project the stuff must be brought right outside the garage onto the driveway. This means balancing a 250 lb saw on my floor jack with a 2x8 across the lower frame. The saw is stored in an area with the router table sitting upside down on the saw. it takes me a good 30 minutes to slear stuff out of the way, left the router table and carry it outside and then work the saw out there.
My plan is to build a cabinet that will roll around when needed (retractable casters) and sit solidly down when I use it. The saw will be mounted on this cabinet and I want to build some drawers to keep the table saw accessories in them. I want to turn one extension wing into a router table so I can use the table saw fence for the router. Also in the drawers I build I can keep router bits, accessories and my plunge router. Does anyone have anything like this that you have made and pictures? I am just trying to get ideas to get started on the build.
