vavet
I need some help figuring out how to set up my table saw to make a cut.
The workpiece is a 28 x 72 x 3/4 piece of melamine. One of the 72" edges is a factory edge - reasonably straight. I need a 45 degree bevel on one of the 72" edges. My table saw has an expandable table, but it only goes out to 24" so I can't use the TS fence.
I have the table saw mounted to a 6 foot long worktable. I was thinking I would just clamp a supplementary fence to the worktable where I needed it, but I think I need to know where the extended centerline of the blade is before I can do that to make sure the supplementary fence is parallel to the blade. I tried using an aluminum straightedge to mark the extended centerline, but when I tried to repeat my marks, I was off, so I'm not sure which one is right. It's hard to align an 8" section of straightedge to the blade to such a high degree of accuracy that any error is imperceptible when magnified out over 5 feet. The last picture I attached shows all the different pencil marks I made at the far edge of the worktable trying to find the centerline.
I've thought about trying to set up a string on a stand so that I could move the stand over a little at a time until I had good alignment with the blade. I haven't tried it yet. I figured I'd query the GJ braintrust for ideas.
