RAS61
In my 40+ years as a professional woodworker I have never used a splitter, riving knife or blade guard.
Ditto - I find blade guards more dangerous. If this is an issue just pay up for a Sawstop
I have the Delta 36-725? from Lowes. It's in between a contractor saw and a cabinet saw. Much larger table area, heavy, yet able to be moved around the garage with the mobile base. I have built a router table into one side as well as a storage box in the other side.
What are your plans for the saw? Will it ever leave the garage/shop or do you want it to be mobile and go from site to site?
Everyone I know has a DW745 and is in love with it.
https://www.amazon.com/dp/B000HXT2N6/?tag=atomicindus08-20
I will likely buy one as well in the near future.
Looking back at my post I wasn't clear enough, I chucked the contractor saw once it stopped smoking for the Hitachi. I'd agree that at the upper end there isn't a lot of difference between a hybrid and a contractor saw but then there isn't much price difference either. Nor are the bigger ones like the delta 2000 all that portable vs something like the dewalt with its folding support stand that lets you roll it away. Though having spent time in a professional cabinet maker's shop I think you're underestimating the difference between a higher level contractor/hybrid saw and a true cabinet saw.I think we're talking apples and oranges with contractor saws, and giving too much credit to hybrid saws. Your Hitachi is probably a direct drive table top model. My Delta 2000 Series Contractor saw has a 1 1/2 hp belt drive motor (same hp as hybrid saws), can use a dado no problem, runs smooth as silk, can cut thick hardwoods (just a little slower than cabinet saws, and the same as hybrids, but how often does this really happen, and what's the rush?), and with my upgraded fence is a joy to use. Would I trade it in on a quality cabinet saw(?) - in a minute, provided I had the cash and room for it. But I wouldn't bother with the more expensive and not significantly better hybrid saw - better to spend a couple hundred more for the saw you really want, and will eventually buy, than this no better middle of the road compromise.
Again, a really good contractor saw is 90% of a cabinet saw, and the equal of a hybrid saw with cash in your pocket - my 2 cents.
I tried the blade guard on mine and it just seemed to get in the way, the riving knife I found especially useful when I needed to rip about 50 2x4 to space old walls out for installing r19. Modern 2x4s **** and seem very prone to twisting and warping and the riving knife helps to keep the blade from getting pinched and jamming. Very rare I've had a hardwood board do that as you can often see a twisted board ahead of time and just don't buy it.Ditto - I find blade guards more dangerous. If this is an issue just pay up for a Sawstop
I think DW745 has 20 ich but it is quite durable
For almost double the price I would hope so!i bought the DEWALT DWE7491RS best table saw i ever used cuts like butter
and 32-1/2 inch Rip capacity also
https://www.amazon.com/dp/B00F2CGXGG/?tag=atomicindus08-20
Yes, l have the"10 year anniversary" Uni-Saw.................Ask and you shall receive grasshopper...
Starting in 1939 the unisaw models have been a benchmark in the woodworking cabinet saws, so much so that the Chinese copy them 24/7.
The newer saws starting in 2009 have a larger 31" x 40" cast iron table top including cast iron wings; making it easier to cut long pieces of wood.
Standard biesemeyer fence system, (The gold standard of modern fence systems).
Single cast one piece trunion system.
Dual front cranks make it a easy to adjust the blade height.
Dust collection system options.
You can buy and find parts on these saws 24/7.
Simple put you can not go wrong buying a used working model.![]()
A do like the safety of the Sawstop but a few things I like better about the current Delta Cabinet saw (3HP or 5HP) over the others:
- More table in front of the blade
- Blade height and bevel adjustment both on front of cabinet saw
- Mass - The Delta is a beast ...much heavier than others
PM 66 out weighs the Unisaw by a considerable margin. A rivng knife is nice but a simple splitter is just as good for ripping. You can add one to the throat plate easily. The only things you can't do with it are tilt and dado. And while those hybrids are fine for casual use, there are good reasons you don't see them in cabinet shops.
......Also, most are right tilt and I found one left-tilt (the one with the Biesmeyer fence above), internet seems to have heated discussions on that. I don't think it matters that much as it would not be a day to day tool....
Unisaw is around 300#...
PM66 is closer to 600#...
I find its actually a comfort thing, being right handed I can stand slightly off to the side and see how the piece is sliding against the fence if it is trying to move, while I don't stand as naturally offside when the fence is on the left side. I've had to make a number of cuts with the fence there but it isn't as natural to me; my left hand uses the push stick while the right is keeping the board steady and it is awkward. To a lefty or someone who is ambidextrous it probably makes no difference. My saw came with an equal length rail to either side of the blade and I'm completely self taught so this is based on natural feel for me and not learned behaviour.The discussions are, that if you have a right hand tilt saw, and you do angle cuts on it, you're risking a kickback because the material is captured between the blade and the fence.....easy enough fix.....I just simply remove my fence from the right side of the blade to the left side! (makes it a moot point)![]()
Don't know why they make such a fuss....
Nice setup! Can you tell me more about the mobile base you have. My delta mobile base only rolls 1 direction easily. I wish it had swivel casters like yours. Sweet outfeed table too. Who made it?
There are many options when looking at Unisaws and depending on floorspace/ power available older saws likely wont have the beismier fence and the fence is worth as much as the saw if you buy one without it and want to upgrade also many unisaws are 3 phase so check what you are buying unless you have 3 phase power . There are also 3 and 5 hp options, and 30 or 52 inch fences and also outfeed tables depending on what you need and have space for. I find the mobile base to be very useful on mine
