Does an 8" stacked dado set fit on a 10" Workforce table saw?
J jlcn2golf New member Joined Jan 8, 2011 Messages 4 Jan 27, 2011 #1 Does an 8" stacked dado set fit on a 10" Workforce table saw?
S snorky18 Well-known member Joined Oct 1, 2007 Messages 1,170 Location Southeast Tennessee Jan 27, 2011 #2 measure how much extra length your arbor has out past the nut. Your dado set can not be thicker than this value. Assuming it fits on your arbor, it also may cut a wider hole in your throat plate. Be careful when you do this.
R rsanter Well-known member Joined Dec 22, 2007 Messages 18,523 Location visalia ca Jan 27, 2011 #3 yea it will how thick you can set it up is a different story bob
T toolsd Active member Joined Jan 26, 2011 Messages 41 Location Chickamauga, GA Jan 27, 2011 #4 Yep, it'll fit fine, no worries as long as the arbor size is correct (which it likely is, both being 5/8"). Tools
M mobetta Well-known member Joined Feb 10, 2010 Messages 370 Location twin cities, mn Jan 27, 2011 #5 I chose a 6" dado for my Bosch portable saw. I got an oshlun from rockler.
