Hey all,
I've been welding for a few months now, off and on but still consider myself very new to the process. I use a Lincoln Electric 180HD with flux-cored wire as I want to familiarize myself with flux-cored before I switch to a gas tank.
I find that when I tack weld, the welds are really quite nice, they look like they have nice penetration and are concave. I tack the weld, wait for it to just stop glowing red and then tack again with around a 50% overlap - probably around half a second between tacks.
When I'm continuous welding (that is, welding a long line without interruption), my welds are rather more convex and definitely don't have the 'dime' pattern.
My question is, is tack welding much weaker than continuous welding? My basic knowledge of welding makes me think it isn't because you're still getting penetration and good pool and isn't TIG welding similar to tack welding? You feed the rod in at intervals rather than a continuous feed.
None of my applications are life-threatening ... I've made a metal working table, a stand for a drill press and so on but I want to create my own scissor lift and am wondering if I can get away with tack welding the entire thing or should I hold off until I get my continuous welding technique better?
Incidentally, I tack welded some angle iron at right angles to each other, put it in the vice and whacked it with a 3lb hammer .. the joint didn't crack, even when the horizontal piece of angle started to bend after repeated hits.
Looking for some input/thoughts from the members here and maybe even some science behind the strength between tack and continuous welding
Many thanks!
Many thanks!
No!
