ThomasT
I had some 3/16" thick aluminum drops left over from a job and I decided to build a small Charcoal Grill. Lots of time I want to cook just one steak or a ½ chicken or couple of hamburger patties and don’t want to fire up my big BBQ Pit and I surely do not want to fry them. This little Grill should be just the thing and only needs a single hand full of charcoal. It is 10" x10" opening at the top and the Stainless Steel Expanded Metal for the grill will measure 9-1/2" by 9-1/4" and I will line the outer edge with 1/4" S/S round rod. The Charcoal Grate will be 9-1/2" x 7-3/4" and it also will be lined with S/S rod. Two sides taper in at the bottom and the two ends are parallel to each other and are 8" high. Later on I might make a lift-off top for it. I am out of 1/4" S/S rod but as soon as I have a chance to use it, I will tell you’ll how it works.
