tahoe won't start
c_mccann
I would run a compression test to verify the timing chain hasn't just a tooth or two, that will verify compression and timing.
60 psi fuel pressure is certainly adequate, and I understand we have spark...
or, if this still has a distributor (which I think it does), set the engine on TDC on compession stroke an see where the rotor points...
I got stuck one day on a old Camaro with the 70's style EFI and we never could figure out why it wouldn't run...but a new distributor fixed it.
And somedays you are down to slitting wiring harnesses with a razor blade trying to find an internal flaw.
Howard
Maybe ignition.... Mine would just wind, wind and no start til it winded for about 25 seconds. It would do it cold and hot- just at random. Dealer replaced the 'spider' fuel assembly, the system always had adequate pressure, not sure of the psi, but it was in spec after spider and fuel pump was replaced.
By any chance was the truck ever run out of fuel?
ratdoggy
Akron-Canton area OH
Neighbor of mine was dicking with his car for a couple of days. The first day I walked over and he told me it just stalled and wouldn't start. One of the questions i asked was does the distributor rotor turn? He said that couldn't be it so I went home and saw him playing with it for a couple of hours over the weekend. I went over again to see if I could help him and I finally got him to try checking the dist. Well long story short he pulled the cap and cranked the engine; rotor no turney. He broke the timing belt.
red97k1500
Texas
What we have is a d*ckw*d who this his own little Fox, Rush, Hannity and Beck driven political fantasy is a good reason to blame the current president for every sin under the sun.
Wonder who he blames when he can't get his cheney up after he has already forked over a few greasy bills the local *** worker.
:headscrat
jay50
Step back from that Tennesse 'pipe
