Tail light .... lights?
Blackbyrd
TN
Sorry for the wonky title name best I could come up with
I have some old tail lights I've had on display in my garage and I was thinking it would be cool to light them.
Trying to guage the best way of doing this? Just appropriate 110 to 12v adapter and branch tail lamp harness off the power supply?
Just looking to discuss ideas
Tail lights are off a 71 camaro and an 06 GTO so 8 led bulbs at most?
Black300zx
Elkton, Md
A 110-12v power supply sounds like it would be the ticket. You should be able to google the bulb part number to find the per-bulb current draw, or simply hook it up to a 12V battery and measure it so that you know how much current the supply needs to provide.
larry4406
Northern Virginia
I think in the “what did you do in your garage thread” a guy recently posted his tail light display lit up via white Christmas lights.
  • Like
Reactions: LSU
Blackbyrd
TN
Saw that! Kind of what started the idea however he had them mounted to a plaque and had enough to justify a string of Christmas lights.
no704
Just dig through your old box of cables and wall warts and find a 12v dc one. Or get one on Amazon for $10.
Blackbyrd
TN
Yeah I got some plans now, gonna need some pigtails for the gto lights....
Thanks guys!
whateg01
doo dah, kansas, usa
I vote for the Christmas lights. No need for external power supply. I would even go so far as to 3d print new sockets that fit the lights but then again if it isn't overkill, is not enough
F-22
You can also google a bit for a nice E17 fitting that could be riveted on the reflector, something like this:
Drill the reflector, rivet (or screw) this on, and use a standard 110V bulb.
E17 come in very small sizes (for fridges, microwaves...)
BTW I did not know LED bulbs can be both 120V and 220V. Good thing the standard size (E26/27) fittings are interchangeable, so I expect this makes global production way cheaper than back when the filaments were different.
Vintage_MPG
Vintage_MPG
There's actually dozens of options online; just not sure which one I'll need....
I need to do some research on 50's auto headlights. Would it matter if they were 6v or 12v? I'm guessing 12v would be much preferable. Just guessing.
dave*99
Coastal NJ
A sealed beam headlight (old incandescent type) can be in the 40-60 Watt range. Use the bulb part number to look it up. Or connect it to your car battery and measure the current with an ammeter or multimeter.
I suspect you don't want full brightness indoors. So a reduced voltage may be best. A series resistor (high wattage type) or a lower voltage power supply may be employed.
You can also connect some of the bulbs in series. To get the brightness you like.
RPH
Michigan Thumb
It’s not unknown to run filament type light bulbs at lower voltages. Many times it’s just to increase durability and lifespan of the bulb.
bwringer
Indianapolis
or rig up some candelabra base 120volt LED bulbs & sockets
This is the way. Cheap, reliable, etc. Or LED Christmas lights or strip lights.
In this application, LEDs have the big advantage of not producing much heat. You can use hot snot to glue things into place, which should also help prevent damage to the piece.
Vintage_MPG
This sounds like the safest and easiest way to get it done.
Anybody have any pics of something like this? Does it look authentic? Can I use the headlight glass up front but light it up with the candelabra lights as my illumination?
Vintage_MPG
I have one of these power converters; I haven't tried it yet, but I suspect it's not enough to push juice to run headlights....
Vintage_MPG
I have several front clips/rear clips that I'd like to hang up; if I can figure this out it will transform my garage! haha!
Vintage_MPG
I'm thinking the easiest way to get this done would be to cut the backs off of a round headlight, then figure out how to mount some standard 110v light bulbs.
What's the easiest way to cut off the back of a round headlight? In a clean manner that would allow for the replacement of bulbs with 110v bulbs? Surely there's an easy way to drill off the backside of a headlight...
Blackbyrd
TN
well I see this is still among the living hahahaha. Granted Ive done nothing with the project kind of forgot about it till I saw this thread haha
AntonLargiader
Charlottesville, VA
If you're adding and powering LEDs for these lights for indoor decorative use, there's no need to stick with 12V. Many LEDs are 5V and you can get dirt cheap USB power cubes for that.
Vintage_MPG
Can I still use the headlight faces - just so that things look relatively authentic?
I like the LED idea; much less power, much less heat, and a much more manageable light output. Win all the way around.
Now how to cut the backs off of those round headlights....
drmarkr
Tucson
Dremel with a cutoff wheel?
Post a pic and you'll get some more suggestions, I'm sure.
Vintage_MPG
Here's what I'm using for my wall hanging, and then a few shots of the bulbs I have...20230412_172140.jpg
backupbeeper
Just use a 120v ac to 12v dc converter ,
I’ve seen some that even had adjustable dc output voltage ,
If 12 was too bright you could switch it to 8 or whatever
Or just use Christmas lights .
