Tailpipe Expander???
gahrajmahal
Cincinnati, Ohio
They have similar ones that that involve a threaded center rod you tighten with a wrench that work well. Hard to be precise when bopping with a hammer is involved.
jrevans
I have one. It works OK.
There are flats on the shaft to accomodate a wrench. I have have never needed to use a hammer except to place it in a flattened pipe end.
Jim
jonny o
I "rent" a threaded one from advanced when I need it... works very well to get the clamp dimples out of pipe and pull an od-to id fit.
tfi racing
Cedar,BC
I have the imitation(Princess Auto) Lisle one as well,works great with the impact gun,can't imagine doing pipe work without one.
D.J.
New Haven IL
I remember using both the Lisle 32500 and the K&D exhaust styles in the 60's and 70's When my dad ran a service station and we did exhaust work. Both worked fine for us back then, and I assume they would still to this day.
________
Blonde Cams
Mattlt
MN
Anyone ever seen one that would be small enough to swage 1/2 - 3/4 EMT conduit? So you could put pieces together like tent poles?
I think this would be a really handy tool.
RobSmith
NSW Australia
I'm pretty sure you can buy threaded socket adapters for these sized conduits...they are screwed for safety reasons in the electrical side of things.
Strouty
Southern Maine
I know this is an old thread, but it was here, no sense in starting a new one. I bought the NAPA professional series tailpipe expander, it was about $40. It was made by KD but in Taiwan. I thought I would try it out. It broke a small piece of one of the fingers off with my 3/8" ratchet. Then I tried the impact and that destroyed what was left of it. It actually took the threads out of the adjustment nut. I think it broke all but two fingers. I slit the pipe before trying this tool! I did not use heat due to the o rings being rubber. I would like to say that these type of expanders should only be used to round the pipe back to existing size. I did purchase a Lisle tailpipe stretching set for $189.
http://www.tooltopia.com/lisle-17350.aspx
That should let me change the ID to fit the OD of the next section. I will report back on the new tool when it comes in.
Here is another thread that discusses the tool I am getting. As well as other "expanders".
http://www.garagejournal.com/forum/showthread.php?t=25912&highlight=tailpipe+expander
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Things just are not made like they used to be.
Like others here I used the hell out of those tools back in the 60-70's and they worked well. No heat or pipe splitting required.
1320stang
Edmond, OK
I rented one of those from AutoZone, it was brand new. Broke two fingers, I removed them and placed them opposite of each other to finish. They looked like pot metal inside, very grainy. I think my problem was using it on used pipe. I was trying to slip a new muffler inside the existing pipe and I believe the heat cycles hardened the old pipe.
bobemmerich
Middletown, Ct.
I ghave a Blue Point version of the one pictured from Lisle. probably the same manufacturer. Bought it about 20 yrs. ago off the SO truck. Works great (although the o-rings are getting old). One of the very few SO tools i still have.
Strouty
Southern Maine
I guess not, If it was just the nut that went, I could understand it being the weak link so you don't break anything else, but when the fingers broke first, I realized that it truly was junk. I borrowed one from a buddy, but it didn't fit, so I had to cut the pipe back further to an area where it would slip into. I did that and it worked. I still can't wait for my new "stretcher" set. I think I may end up getting some of the other style as well just for making the pipes round in a pinch.
Kev442
Wi
Broke one HF one for each pipe I needed expanded. Job is done with one extra trip to HF. Would not recommend one.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Could be, but the old tools never seemed to have a problem on used pipe except for cracking usually due to thin spots from rust.
We replaced the O-ring on the tool once with a bunch of rubber bands for a quick fix. I liked the old tools with 3 or 4 O-rings.
70redbee
Knoxville,Md
I have several sizes of these and 2 different types. They are both made by Lisle. One is just to remove the dents from the clamps and true up the roundness. The other is actually an expander to increase the inside diameter for slip joints. You need to keep them greased and cleaned for proper use. Mine are all the type that has a bolt to tighten the expanders and have never given me any problem, work great. Just as a side note the O rings are only there to keep the jaws together and lined up, if they go bad any O ring or rubber band of the correct size will work. Just remenber one size does not fit all.
ket-tek
Anyone know if one that is actually strong enough to expand 304 stainless steel? I've tried the HF and the autozone rental and both broke before budging the pipe.
