taking apart a S-O ratcheting screwdriver
jride200
Thanks for the tips. Do the hard handled screwdrivers even have a pocket for the ball which is used on the shank of the soft handle screwdrivers?
ricleh
Sacramento, CA
I believe the internals of the hard handles are the same as the soft handles. I put the shafts from the soft handle set into the hard handles and they lock in place just like in the soft handles.
bonneyman
Desert SW
I picked up a T-handle ratcheting driver, and the "Snap-On" logo was barely readable. Figured it was worth something, so I brought it home and took it apart for cleaning/lubing. Internals looked just like yours.
But I found it a bit cheesey construction. The pawls and inner splined collar are high quality steel, but the body seemed almost like pot metal. Could not get it to run smoothly. I think the inner throat of the body was worn out of round by hard use, and the splined collar would **** sideways and sieze up.
Eventually just filled the guts with epoxy and let it set up fixed:shocking:, plus removed the distorted 1/4" knuckle and installed a swivel.
Todd.Brock
Cincinnati
Thanks for the tips. My soft grip took a dive into the sump pit while replacing the pump. I let it dry out but the impact must have moved the internals around. I disassembled it , cleaned, little grease, and voila... good as new. Thanks! :thumbup:
jride200
Step 4: If rebuilding, replace parts and skip to step5 If removing shank to allow multiple shanks/blades remove "spring ring retainer" from shank.(looks like a lock washer)
Does anyone know if the "spring ring retainer" is reusable? Can I swap around shanks on my hard handle drivers, to best suit my needs, and reuse the same retainer? Thanks in advance.
P
plinker
Northern Wi
Yeah, it's reuseable.
One of these days I'll pick up another short bit shank to put in a regular handle screwdriver and that will keep the shank in place (as I dont want it removeable).
Golfer
Plinker, I just want to say thanks for some great info!
I just lubed my screwdriver using your instructions and it's now smooth as silk.
I just got a used bent handle and there seems to be quite a bit of resistance on this thing to the point where it's hardly a ratcheting screwdriver. What are you guys using for lube as I think they used molasses in mine.
Brucegbombara
Long Island, N.Y.
I just recieved a rebuild kit in the mail because the do not make the ratchet screwdriver I have ssdmr24 and to be honest it looks a little intimidating lol. Theres alot of pieces in the kit. I guess when I get the nerve up I will give it a shot. I've taken the cap and shaft out before but I didn't realize there were so many internal pieces
Brucegbombara
Long Island, N.Y.
So I did the rebuild and it was very easy. The only problem I had was that lock washer piece that goes over the shank. The old was was hard to get off and the new one was even harder to get on. I think I kind of bent it getting it on. But the ratchet works well now and the shank seems to be on there securely. Any tips on getting that piece on without damaging it would be helpful
P
plinker
Northern Wi
Generally speaking it's not a hard job to do but making sure everything is lined up and compressing retaining ring is at the same time can be a trick sometimes.
For the retaining ring, I pry from side to side to get it off take a little time but is the best way I found. To install it, a socket would work to start it and if it's a deep socket to drive it on the rest of the way. A 7/16 or there about should do it.
It does a specfic area it has to be in to be effective(can't be to much or too little or it wont go back together right), so it's a good idea to mark the location before removing the ring with tape or paint or what not.
I put a short shank (the interghangeable style with the detent ball) in my one hard handle style driver and used the blade/shank retaining ring on it as I didnt want it interchangeable at the time.
bmwohio
Columbus, OH
Awesome! Didn't know this thread existed. Just did this to my well used SSDMR4A, and it is MUCH smoother now. This is just like taking a part and re-lubing a SK 45170.
If you have not done this in a while, I would recommend it. Took me about 20 minutes to do :thumbup:
losabio
I used the photos and instructions in this thread to SuperLube up my trusty ratcheting S-O screwdriver. Thanks! I used a pair of Wiha "heavy duty" tweezers like this for the retaining ring.
supra90turbo
Central MA
I have something to add to this thread. To those looking for a way to keep the shank in the driver somewhat securely I have found a solution, much like the newer ratcheting drivers have (I assume, I haven't seen one personally)
It's a small A/C seal. It's aluminum with a rubber or viton seal on the inside. With a small amount of grinding on the OD you can make it fit into the recess of the cap and it holds the bit very securely.
It's a GM part, 52477087 is the number and it's $9.64 list price
I can provide anyone with a seal if they want for around $7 shipped.
-Kurt
P
plinker
Northern Wi
Cool, thanks for the info! Looks like a good fit.
The little deal with the soft grip ones is it's basicly a rubber washer sized to fit the recess. I think I had posted a pic.
Biomed
Minnesota
Did anyone ever find a source for the rubber washer/bushing that goes inside the cap? Does it come in the screwdriver rebuild kit? I've got a SO hard handle ratcheting screwdriver and a Williams ratcheting screwdriver that I am considering modifying to permit use of different shanks and blades but I would really like to have the rubber washer/bushing.
Biomed
Minnesota
Look up, I found a solution not too long ago...
I saw that but it is much easier for me to order from Snap-on if the part is available (individually or in a rebuild kit.) In addition, I do not have to do "a small amount of grinding."
Could you use an O Ring?
Perhaps but I wonder how long it would last? Don't want to have to disassemble my screwdrivers periodically to replace O-rings when the part designed for the job may be available from Snap-on.
Bolster
Mexifornia
Thank you for this tutorial Plinker. I hereby bestow this award upon you:
With your instruction I fixed my screwdriver T-handle. I had pulled the shank out thoughtlessly, thinking it was like my stubby ratcheting screwdriver.
The shank won't go back in these non-interchangeable T-handles unless you disassemble, push the one-way "lock washer" back on, and reassemble.
Sick Puppy
Sydney
Looks like I'll be joining you Bolster in repairing mine - I went a bit SO crazy over the last fortnight, and the first one to arrive was a used Tee-handle with a 4" shank.
Selector cap is cracked and out of alignment, so I'll have to strip it and replace the cap. Just as well I paid not very much for it... too mch hassle to ship it back to the US :mad:
P
plinker
Northern Wi
I doubt they'd warranty it (probably used for prying), but if you have a dealer you could try. Or just convert it for interchangabilty so you can use multiple style shanks.
jjjrmx5
Cincinnati, OH
They have different shanks? What kind of cost do you think?
There are two types of S-O ratcheting screwdrivers out there: fixed shank and removable shank,
The fixed shank units came with and internal clip that holds the shank fixed into the handle. The removeable shanks swapped that clip out with a friction fit o-ring and mechanism.
Swap out the guts with a OEM repair kit for a removable shank driver and just buy the shank length you want. They come in stubby, std. and long.
Kits work on both soft grip or hard handle.
IIRC, you can buy a new fixed shaft shank and then just replace it alone. My driver had done it once for a co-worker.
jeffmoss26
Cleveland, Ohio
Hey jjjrmx5, I like your signature!
This thread helped me rebuild several of my screwdrivers...so I am going to help you!
Part numbers for the end caps:
SSDMR4B1TT - black
SSDMR4B1RTT - red
SSDMR4B1OTT - orange
SSDMR4B1GTT - green
Part numbers for the reverse caps:
SSDMR4A6TT - black
SSDMR4A6RTT - red
SSDMR4A6OTT - orange
stonesfan68
Houston, TX
SSDMR4A6TT - black
SSDMR4A6RTT - red
Do these reverse caps include the seal that is required to use the interchangeable shafts in the hard handle screwdrivers?
jeffmoss26
Cleveland, Ohio
I don't have any shanks other than the normal ratcheting screwdriver ones. By removing the retaining ring, they become interchangeable.
P
plinker
Northern Wi
I've not had an issue using interchangeable blades in a modified screwdriver that does not have the reverse cap seal washer. It would be nice to have in there though, and there are a couple options listed somewhere in the thread. I just never got around to it.
MrRaceInc
Great post! The Snap On ratcheting screwdrivers are one of my main tools. I have cleaned and rebuilt them several times. The getting it back together is the part that never gets any easier! Good thing I am a patient man!
