ClappedOutBport
- Joined
- Mar 30, 2016
- Messages
- 998
Our Massey Ferguson backhoe that you can see in other videos needed some front end work (kingpin bushings mainly), but we figured while we had the steering cylinders off, we would rebuild them. Unfortunately a standard pin spanner wasn't up to the task. So I ended up having to make a special tool to disassemble them, and they ended up taking over 350 Ft-lbs to come apart!
The cylinder had four 1/4" spanner holes spaced on a 1.6" hole pattern and were about 1/4" deep. I used non-harded pins that unfortunately, bent a little, but they got the job done.
