strutaeng
Hi guys, I'm working on installing strapping on my addition project. The ceiling joists are 2x12 @ 24" o.c.
My framer installed them with a positive camber (sad face,) as he should. The problem is than they are higher than the adjacent ceilings joists. This was not evident until I started installing my 1x4 strapping for the drywall. Normally around here the drywall gets installed directly on ceiling joists; that's not really relevant to the issue, just an FYI.
Does anybody have any ideas. Maybe just shim the strapping so that it is level? The worst ones are about 1" higher than the rest.
I thought about installing some plywood in the attic and putting something heavy up there to bring down the hoists that are upward, but that's a lot of work, and probably a lot of sandbags, LOL. I suppose I can calculate the load to produce a given deflection, but that does not seem practical?
I know if I kerf the bottom of the joist it may come down, but don't want to reduce the capacity of it. The span is about 22'. It will be just attic, so just random light stuff stored up there.
The real answer is: "You should have used TJIs!"
