Taking Racedeck tiles apart
DanEC
Arkansas
Received my shipment of RaceDeck tiles and getting ready to install them. Since they come in assemblies of 4 tiles hooked together I will need to take a few of these apart for various areas like the border. What's the best way to separate the hooked together tile without damaging them. There are instructions on the carton about how to lay them out and assemble them, but I didn't see anything on how to disassemble them.
Thanks in advance
SteveCh
When I received my tiles, I watched the short video on their web site about how to do just that. After about three minutes of trying it, I was able to do it with zero trouble. For me, I found that a stiffer-bladed putty knife worked a bit easier than a more bendable knife.
Shea
California
It's much easier than that. Hold the tiles surface up in front of you. Lift your knee up and smack the tiles over your raised leg with the joint aligned over your leg. They will snap loose with little effort. After a couple practice tries you will get the hang of it.
D
DanEC
Arkansas
Thanks - I'll give the stiff putty knife and the over the knee a try and see what works best for me.
Al G
Arizona
Over the knee worked great for me. You only need the putty knife once they've been installed.
CJDave
Fairfield, Ohio
Over the knee worked for me just fine. A VERY stiff putty knife works when once the tiles are installed and you need to correct a error in your pattern or such. Straight out of the carton I used the knee method. CJDave.
