Tamper proof recepts, 2020 code
walrus
Maine
Attached and detached garages, accessory buildings associated with a dwelling unit will have tamper proof recepts. This proves I paid attention to something in my 15 hr code update class ;)
nadogail
Coronado, CA
Thankfully that particular upgrade has not , to my knowledge, become effective on any of my properties.
Wrench97
Southeastern Pa
Saw a maintenance guy last week installing them last week of course he wired them backwards with the black wire on the silver screw side and back stabbed of course.
I'm going to feel so much safer now........................
Norcal
Doofy strikes again.
acer66
Western North Carolina
I am not sure what the big deal is. They are slightly more difficult to use but it isn't anything noticeable after a while.
Me either and I developed the habit to check the prong length if it does not work and more often then not they are so different that I have to plug them in in an angle which then works.
WisJim
Menomonie, WI
But TR isn't required for 240 receptacles, and I have a lot of them, lower than the 120s. Makes little sense to me. Regarding the door opener receptacle, I don't think TR is required if over 5 1/2 feet from the ground.
Daveco
Texas
I’m wondering how long the little tiny plastic pieces inside will last before they start falling apart and jamming the slots.
W
walrus
Maine
I think the 5.5 ft refers to where recepts shall be placed. Don't think that excludes TR above 5.5 ft.
jkeyser14
(rural) Maryland
Wow you guys really fear change... TR receptacles are pretty decent these days. I have been using them for 5+ years with zero issues. The early ones had a little more plug insertion force, but the more recent ones are really decent.
purplezr2
Central MN
My whole garage is TR outlets, radiant by Legrand, and they work flawlessly.
I can say I honestly don't even notice they are TR.
I have some other Legrand outlets on the outside of my house and they are also TR, but I do notice one is tougher then the other to get in.
tdkkart
Eastern Iowa
We will all feel a whole lot safer with ceiling receptacles that power garage door openers being TR.
The day will come when all door openers will have to be hard wired, technically preventing the average homeowner from installing one.
Robbie B
Sunny side of hell
I’m not an electrician and I know not to do that. [emoji2359]
exranger06
CT
Weren't they already required in those locations for the last few code cycles? I thought 2014 required them.
No, any receptacle that's at least 5.5 ft from the ground doesn't need to be TR. Also, any receptacle that's behind a large appliance that you can access only if you move said appliance, doesn't need to be TR. For example, the receptacle behind your refrigerator doesn't need to be TR. Not many little kids are going to push a fridge out of the way just so they can stick a paper clip in an outlet.
I also don't see the big deal with requiring TRs. I've replaced every receptacle in my house, for several reasons, and I used TRs in almost every location. I like bringing things up to the latest code when doing electrical work (even when it's not required) and I like the added safety with 3 mischievous little kids running around the house.
u2slow
BC
It will take a few years to use up my non-TR stock around the house and shop. Also the non-TR will be on discount/clearance for a while yet.
I also wired the fridge outlet so its not behind the fridge. I like to be able to hook it up to my generator's extension cord without moving it.
Somehow I resist the urge to poke foreign objects into receptacles... :evil:
exranger06
CT
Adults typically know better. Little kids, not so much. The whole purpose of TR is really just for kids. That's why TR is not required on receptacles over 5.5 ft from the ground (kids can't reach), and not required behind large appliances (kids can't access). That's also why they're required in places where kids are likely to be, such as homes, schools, hotel rooms, daycare centers, etc. and they're NOT required in commercial office buildings, factories, industrial buildings, etc.
dave*99
Coastal NJ
FWIW, dishwashers had usually been hardwired. Now I see them connected with a plug and receptacle (usually under the sink) This is to provide a local means of disconnect for service/repair/replacement.
dcg9381
Austin, TX
They clearly did not write code with GJ people in mind.. Agree, it makes no sense in a shop context.
Somethings get "unupgraded" if they were installed that way in my shop...
We started getting these in residential about 10 years ago (at least the house at the time got them) - they really weren't that bad...
With these things installed, it'll definitely limit the child - electrical learning curve... I know I only did it once.
cadunkle
I got caught by code enforcement doing renovations years ago, they made me swap all outlets from the quality model I chose to TR junk. No kids and I'll never have them. After countless times getting frustrated trying to get something plugged in I changed them back. This summer I changed a couple TR outlets at a relatives house to standard, since you couldn't get anything plugged in. They were using a two to three prong converter on their three prong plugs as that was the only way they could plug anything in to the problematic outlets.
u2slow
BC
Adults typically know better. Little kids, not so much. The whole purpose of TR is really just for kids. .
It took until 2020 for kids to matter? The plug-in safety 'blanks' have been available for 40+ years.
Is this really a safety thing? Or a reason to clip everyone an extra $3.50 per receptacle per household? And we thought housing was already too expensive... :lol_hitti
Shiftless
East Bay SFO
And I see that you can buy TR receptacles with the back stab option.
Shiftless
East Bay SFO
“Backstab” is a push and pray device, backwire is the screw plate type.
Right
Maybe those inexpensive Levitons do have the screw down plate time of wire clamp and not the “push and pray” as you so accurately described. I don’t know, I couldn’t find a view of the backside of the device.
I like those screw down plate devices and haven’t used any other for several years now.
stickshift
northeastern US
NEC is very non-progressive in their thinking. It's 2020, we allow little boys to decide they are little girls, but we can't trust them to not stick metal objects into electrical outlets? :Homer:
