Jwych
So today I had an ecu on an air valve I needed to swap to a new valve and it had t30 tamper proof torx bolts securing it. When I got my gearwrench torx set out and attempted to remove the bolts the middle post inside the torx pattern was to large to fit inside the hole on the torx bit. I also tried a buddies blue point set with the same problem. Has anyone also encountered this?
