andis65
I installed a Bosch aquastar 240fx for my radiant heat flooring. It's running as designed, temp is fine, but it hums quite loud right underneath where the flue exits the boiler. Its not constant, it will hum then operate quietly then hum again. It's related to water flow, my system has a 3 speed circulator pump and I can get it to change sound by changing speed. The fan runs quietly after the unit turns the flame off, so it's not that. Almost sounds like expansion but it doesn't reach a happy spot. Anyone have any ideas???
maybe since the heat exchanger is above (like 12") the outlet port on my tank less water heater the 12 pounds of water pressure couldnt force it out?? who knows... working great now though!! thanks for all the help building this system!!
