Tap 1/4” steel
Rc_Guy
Minnesota
I have threaded probably a couple miles of pipe it seems like but have not tapped any thicker steel, any tips on tapping a 1/4-20 hole in about 1/4” steel?
dr_clyde
Holland, MI
By hand I assume?
Blind holes or thru?
Just one hole or lots?
I would recommend a tapping block to get started. That will keep the tap straight, which is a much bigger deal on thick stuff. If your tap starts crooked, you'll eventually bind up and not be able to go farther. A tap block will help keep everything square with the world.
Unless you're tapping a blind hole, I highly recommend spiral point HSS taps. Personally I use Butterfield, but any industrial brand will work. These push the chips ahead, unlike a hand tap. This means you don't have to stop, break the chips and clear out the flutes. The downside is they want to start crooked unless held in a machine spindle or with a steady hand/tap guide. If the hole is blind, a spiral flute tap will do the same as a spiral point, just in reverse.
Use dedicated tapping fluid. My favorite is Mike-o-cut, but tapmatic, tap magic or even the Rigid pipe threading oil will work. Don't use engine oil or penetrating oil. WD-40 works on aluminum, but I don't recommend it for steel.
Boogerman
aspen cove hill
Edit: Dr Clyde covered it pretty well while I was typing!
How many holes, and is it a through hole?
Tapping a hole is pretty easy. First, drill it to the correct diameter. Use a tap chart, and the size of bit for the class of thread you want. That's the reason there's numbered and letter bits, to get the precise size. Then, it's just a matter of starting the tap at 90 degrees to the surface, and threading it in. Use a high quality high speed steel tap. Coat the tap with cutting oil. If you're just doing one hole, and you're not particular about thread class, just eyeball the tap for squareness, or use a square or really anything with a 90 degree angle to check that you're doing it straight.
If you're doing precise work and the workpiece is small, I recommend tapping in the drill press or milling machine. On the drill press, just put the tap in the chuck, put a small amount of down force on the quill, and turn the chuck by hand to thread the tap in. On the mill, I use a spring load tap chuck that allows the tap to self feed into the work.
Another option is a tapping fixture, I have a Phase II, that holds the tap square to the work, and has a crank to turn the tap in.
Many people advocate turn the tap backwards and forwards to break the chips free. You get a better thread if you just thread it in, and if you have a good sharp tap and cutting oil, it's unnecessary. If needed, blow a bit of air down through the flutes in the tap to clear the chips out the bottom of the hole.
One trick for beginners that don't want to invest in tap guides or a tapping fixture is to drill a hole through a 2x4 block with a drill press so it's square. Use that block to hold the tap to start it square. You can make more permanent ones by using steel or aluminum blocks, and for production work, could use hardened steel drill guide inserts.
Jgaz
X2 for Big Gator tap (and drill) guides.
The three I have now let me give away or scrap an almost full bread loaf pan of tap and drill guides I’d made and saved over the last 40+ years.
dr_clyde
Holland, MI
Do you clamp that thing on? Or just hold it after hole is started?
Depends on the part.
I usually start the thread, then if I need more clearance, I'll slip off the tap wrench and pull off the block, then keep going. If it is a fairly shallow depth of thread, I just leave the block on.
dnschmidt
Phoenix, AZ
If through hole I also recommend a gun tap (spiral point tap). I use a Milwaukee corded drill with a key chuck or the really good all metal Japanese keyless chuck Milwaukee used on their Magnum drills to actually do the tapping. I've placed a bubble level on the back of the drill to get it fairly straight and power tap the hole if I've got more than one hole to drill and tap. I use Anchor Lube or Boelube on the tap but Tap Magic works fine as well.
Sumboodie
AK
I never heard of one of those things until now. There's been many instances where I could've use one.
I've made a few with just drilling a hole in some square tube when I had a bunch if holes to tap, especially at odd angles.
Jgaz
I’ve showed this picture on this site before but maybe it deserves to be repeated in this thread.
Big Gator drill guide (made in USA) clamped to the axle on my pressure washer in order to cross drill a hole for a cotter pin.
No way I could do this as easily or well by hand and eye.
Axle is welded to the frame so a lot of disassembly would be necessary to fixture this in a drill press.
R
Rc_Guy
Minnesota
Two holes, just in a pair of tongs for the outdoor fireplace. I want to put a piece of chain connecting the two sides so they only open a certain distance.
Sumboodie
AK
I'm assuming you had a drill press to get the hole straight in the square tube.
Hand drill is fine too. Easy to drill reasonably straight on a bench vs under something in the dark with arm stretched out.
BillK
Beautiful Southern Maryland
I would have been done quicker than it took to type the question. Just make sure you have a sharp tap and use tapping oil if you have it. If not 10w30 will work just as well.
Davefr
OR
Sometime I cheat and use a drill bit just a tiny bit bigger then what's stamped on the tap for thicker steel. By bigger, I mean just the next tiny increment in size. For example a 1/4-20 hole says to use a #7 bit (ie .2010). For 1/4 thick, I'd choose a 13/64 bit at .2031 which is the next bigger drill bit on the chart.
A broken off tap will ruin your entire day.
This assumes it's just a general shop project and not something super critical.
no704
I’d use a nut and bolt on that. Or a cbolt thing like a carabiner but open on one side with a threaded barrel. Can’t think of the name right now?
rdoty
Massachusetts
Don't use cheap taps - the ones you get in sets from the big box stores or Harbor Freight. Pick up two or three 1/4" high speed steel industrial taps. Don't get cobalt or carbide taps - they are brittle and tend to snap unless you are using them in something rigid like a milling machine.
Make sure the tap is sharp. As noted above, make sure the tap is perpendicular to the surface. If using a regular tap wind it backwards periodically to break the chips.
Don't force the tap - that is how you break them. A good tap running straight shouldn't require that much force. If it gets hard to turn, stop, back it out a turn or two, and try again. If it is still hard to turn, back it out and figure out what is going on. A broken tap is like a broken bolt - except it is too hard to drill out...
Based on recommendations here in Garage Journal, Harry Epstein is a great place to get taps.
I’d just open the two links of chain drop them thru, and close again. Just need a big enough chain.
Edit: or maybe not, forgot about 1/4” thick, those don’t look that beefy. Chain that would fit would be too beefy, and welded.
