Tap and Die Question
MichaelBikel
CT
What is the difference between a regular Die a re-threader and a thread restorer? Sometimes I cut bolts to length with my chop or hack saw then use a threader to clean them up, it works but is this a bad way to do so? Sometimes I just do it because I need specific length bolts...
Bdgjr215
You can also take the bolt to the bench grinder and swirl the thread into itself
At the bottom . No need to chase threads on a new bolt
Tim37
I have found that If I run a but on a bolt before I cut it the take it off it will fix the threads on its way off.
RogueFab
Oregon
Don't forget to keep a triangle file around for thread work too. One more good way to clean them up.
The nut trick is good too. I use it.
I have had great luck just cutting a chamfer on a lathe or with a grinder without clean up.
My old dies are "thread repairing" :thumbup:
2oolhound
BC Canada
I put a threading die on backwards, then make the cut, file the last thread starts down as they are fragile at the tips and then remove the die. If it's a permanent thing where I'm likely never to need to remove the nuts again I may not dress the end threads with a file, just remove the die and carefully install the nut.
mikeceli
"Thread Chasers" repair the thread without cutting the hole larger, bolt smaller.
I have a set and use them often! regular taps/dies take off valuable metal.
