Tap and die set
Mccool
Anyone have recommendations on a good tap and die set? I'm currently looking at this Century set.
Most of my work consists of cleaning up old threads but I will be cutting new threads occasionally. I know I can buy nice taps/dies individually, but it would be nice to start with a kit so I have a wide range of sizes.
Any thoughts?
Craftfab
Garage
If most is cleaning old threads, I have been using the Lang Thread Restorer kit the last few years for just that use case and it has been great. It is US made and my understanding is the OEM for the tool truck brands that sell the same thing with their name on it.
jayemm
up high down low
Any thoughts?
For the price of that Amazon set (or possibly less) , you could get a couple of smaller sets that would total to be more pieces. Maybe even get a 60 piece SAE and metric set without the EZ Outs. Depends if you want metric as well as the larger sizes above 1/2". The Alfatools brand carbon steel taps and dies are the same as the Century brand, with both being made in Japan by SKC. https://fastoolnow.com/search?q=tap+die+set
Here's a recent thread on the subject. Also try the search function. https://www.garagejournal.com/forum...ot-bank-breaking-tap-and-die-set-help.493325/
Mccool
Thanks for the advice so far. I didn't know a restorer/chaser set was a different thing. I think I'll start with that Lang set posted and add as needed.
fsae0607
San Fernando Valley, CA
Yeah, the Lang Thread Chaser set has saved the day countless times! That's what you want to use for repairing damaged threads, as they "roll" displaced material back into the thread profile.
Taps & dies cut material, which can weaken threads by potentially undercutting them. It's been beat to death here and you can get away with using a tap to clean up non-critical threads. For something load bearing and especially subject to tensile fatigue, no way.
^ If the intent is simply to "clean up" existing threads, then a "thread chaser" (like those Lang made units) is what should be used.
Taps should be used only to cut new threads - not to clean up old ones.
LB-1911
Northwestern Il.
Another source for rethreading Dies & Taps is Jaw Manufacturing
:see:
:beer:
