Tap and die storage
Manatee91
I have finally given up on the molded case that my tap and die sets came in. They never did keep them organized and as I have replaced bits they no longer fit I the cases leaving me with a pile of taps and dies in the top of my tool box. I have come up with a good solution for the dies but I am still thinking of a way to store my taps. I am leaning towards a drawer set that I can mount on the wall.d0fc2c17fae6e8caab0da746167798ad.jpg
kbs2244
I lay them out on an old towel, about an inch apart, spray with WD40, and roll them up.
oldwino
Sonoma County California (wine country)
Certainly not the best method but I place mine in 3x5 envelopes (like you get when you have keys cut) with the die, tap and correct drill bit. Mark envelope with correct size then placed in a card file box.
lilredex
Toronto
Here is what works for me. If you are nervous about the taps in the S-K box (never had a problem with that arrangement), you could just leave them in the original packaging as in the last picture.
PhysicsDude
Dallas, TX
That's a pretty nifty storage solution. You could probably fit 2-3 dies of the same size if you have duplicate sets, or have a spare.
Thanks for sharing.
Huot has a lot of good products for storing/organizing bits and taps, but I'm not aware of any product they make that's really effective at storing dies, or at least not one that's suitable for most home-users.
MFolks
Springfield Mo.
Get some nice clear 2X4,drill to hold tap,the clearance drill bit, and the tap bit size,stored vertically, maybe use a stamping numbers and letters kit ,filling them with fine tipped marking ink,so it won't rub off easy.
Manatee91
For taps I really like the huot indexes. This one stores the taps and drills in one place:
https://www.huot.com/products/tap-and-drill-nc/
I was looking at them but they seem to only have one slot for each diameter.
Thanks for sharing.
I have one that has 3 in it but I wouldn't go beyond that it gets hard to get them out
nice idea
I'm looking at your 1/4-20 & 28 dies, an odd looking 1/4 marking?almost looks like 1/2
Oops that was a goof.
I had thought of that but I was looking for something that wouldn't take up the entire top of my tool box.
Manatee91
It was really just me being OCD and wanting it easy to find the one I need when I need it.
matt_i
Good solution on the dies :)
For taps the best system I've seen is a lista design (and possibly others) but there's a U-profile insert which cradles the tap in a pocket and keeps it from getting stuck in the bottom corner of the pocket where your fingers can't reach it.
If you had the time and inclination, you could bend the pieces out of thin sheetmetal, even light duty like trim coil would work just fine. Then figure out how to adhere the metal pieces to the organizer box, thinking silicone caulk would work, or other construction adhesive, superglue, school paste, etc.
WhoWhatNow
Collegeville, PA
They have individual indexes for NF and NC, but to store taper, plug and bottoming you would need three.
They also have a dispenser that would cover everything.
https://www.huot.com/products/tap-fractional-2/
Stuart in MN
Minneapolis
If you're happy with the plastic cases for your dies, how about using the same type for the taps as well? Chances are you can get them with different dividers inside, or else you can fabricate your own dividers to suit. That way, all the dies and taps are in the same format storage and can stack together nicely.
rsanter
visalia ca
I have gone to doing the same thing.
Since I have anywhere from 2-6 of the same taps and dies, it takes less room to store them this way, plus I can still grab the whole box to take to the workbench
Oamaru, N.Z
sir how about using a real nice bit of exotic hardwood or go to a undertaker who makes coffins an ask for offcut mahogany?. make a series of progressive drill holes and your done.
Cape Coral
I had a bunch of extra taps and dies. Picked up a square ice cube tray from the dollar store for the dies and ordered some long ice cube trays for water bottles from eBay. Put the duplicate sizes in milkshake straws so they don’t bang around each other and regular straws for the smaller ones. Stacked the trays onto one another. 841E20EC-6A44-4535-A2BD-ECC8EF9578C7.jpg
Mattlt
MN
Look at the plastic cases that have adjustable dividers. Use a square shaped one for the dies like you already have. Then make up a rectangle shaped one for the taps, in-line with the die compartment.
I like the idea of the water bottle ice cube trays too. :beer:
anythingyoucanimagine
New England
Hospital crash cart very similar to this:
