Tap or chase? Pics inside
Sdot
Loading
Hi guys
trying to figure out best way around this. Steel material. There are decent amount of threads in tack here so will using a tap cause loose fitting bolt? Or cross threaded mess?
Right now bolt can’t be threaded in by hand. About 1/2 turns and it hangs up on something.
thanks in advance
Bigblue&Goldie
A tap might work if you can get it in there properly. Taps "cut", therefore they remove material. A thread repair tool re-forms the threads, so in theory they should work better on damaged threads. If you have to buy a tool, I'd say get thread repair tool. If you already have the tap, I'd probably give that a try.
nadogail
Coronado, CA
Because there are many variables involved; such as what stress is there on the threaded connection? The thickness of the threaded material? is there a need for the connection to be leak proof? and other considerations that don't immediately come to mind plus I have not seen the problem; I decline to say more than "it depends".
4 FN 27
Minnesnowta
I agree with Chasing the treads not cutting. But you might try a Roll Form Tap if you are worried about cutting and making the thread out of spec. They can be pricey but very effective.
PCustoms
VT
In a pinch I've ground a slot lengthwise in a bolt and used that as a thread chase. The bolt won't cut new threads, and the slot leaves room for the paint to clear.
I really think you've got the wrong bolt though.
What is this on, and what size bolt are you using?
larry_g
oregon
That also looks like a through hole? Can you thread in the screw from the back side and see if it will go in and hang up at the same spot? Are there other threaded holes in this piece that you can confirm that the screw threads into properly, even if you have to remove another fastener? Have you examined the fastener closely to confirm that it has no damage to it?
lg
no neat sig line
Sdot
Loading
Appreciate the replies guys and to answer a lot of your questions. 110% sure of the bolt size and pitch: m8x1.25. Connection doesn't need to be leak proof and no access from the back side. Hardware that came out was a bit fajunked up also, which I ran through the metric Lang thread chaser set I have (gold bits).
Been trying the Lang thread chaser. But get nervous when it hangs up. Not wanting to push it through the threads (though that's what it needs to do) I have a feeling this is where I need to be really careful if its cross threaded or not. Any way to even determine that? or get through it?
Thanks again
PCustoms
VT
Thanks again
Ok, what is the part?
Some of those nuts are lobed/pinched or have an interference fit as a self locking feature.
Sdot
Loading
okay, after some digging. It’s a “Dog-point” bolt that was removed.
This may help a lot with diagnosing.
also did pick up an Irwin tap - but not jumping there yet
PCustoms
VT
Not from my perspective....
What the hell is this super top secret bolt application?
htmdude57
Hudson Valley, New York
I don't think there is anything special about a dog bolt's threads? Dog bolt is just a bolt with a reduced size tip. I think there are lots of them on cars.
Sdot
Loading
Not top secret location- just not interesting.
got it. Only made mention of them since didn’t know if that effects how you tap or which type tap you could use
Jlarson
If I know the thread is right I'll run the Lang chasers hard. I use em with an electric ratchet a lot on multiple holes a lot, they are pretty tough.
Sdot
Loading
Making some progress here (or so it feels) with the Irwin tap I got today.
only have it in a bout 2-3turns. But it’s getting through some junk with a tight hand turn and then slight turn backwards, repeat.
getting the t-handle on while it’s in the hole is dangerous…and only way I can “feel” is by hand
Sdot
Loading
Deed is done! Thank you everyone for your help.
got the bothered threads corrected with the tap, and rest of threads were all good! Phew! Lucky!
Love this place.
