Tapcon
mackrmnn
Midlothian, VA
:beer:
tcianci
Walpole, Ma
The Tapcon is a self tapping screw made for brick/masonry materials. Each different screw size has a corresponding Tapcon drill bit. The bit is carbide tipped for the masonry materials. Once you drill a pilot hole with the correct bit, you can drive the screw in just like you were driving into wood. A word of advice: When fastening with Tapcons, once you bring the screw up tight to the object you are mounting, any further torque applied to the screw only serves to strip the thread or snap the screw. Bring it up good and snug and you're done.
Bencrx91
Gatineau, Québec, Canada
The reason TAPCON snaps is because there is a minimum and maximum depth you can use them with. It aint written on the package lol.
But here it is :
http://www.concretescrews.com/instructions.aspx
Determine the appropriate length Tapcon® concrete screw for your project
Standard Blue Tapcon® and Stainless Steel Tapcons®:
Before starting any project, it is essential to determine what length of Tapcon® is needed. Below is a formula to easily determine the length of concrete screw needed.
Add: The thickness of material to be fastened
-to-
The minimum embedment* required for the diameter of Tapcon® concrete screw being used.
* Can be found in the chart below
Tapcon® Diameter Minimum Embedment Maximum Embedment
3/16" 1" 1-3/4"
1/4" 1" 1-3/4"
3/8" 1-1/2" 2-1/4"
1/2" 2" 2-3/4"
5/8" 2-3/4" 3-1/2"
3/4" 3-1/4" 4"
brownbagg
another tip, use a screw gun and not a drill, start the screw and dont stop till you hit bottom. stop half way and its over with
djd99
Owosso,Michigan
The best way to install tapcon's is drill the pilot hole with a hammer drill and I use my dewalt impact to set them in place, don't stop until the tapcon is all the way in. The auto shop is entirely made from cinder block so I have them all over. They hold extremely well.
jwith68
EC Missouri
I don't understand the logic behind that.
Dynamic (moving) friction is considerably less than static friction. Once you have stopped, it often takes more torque to restart the Tapcon than it can handle, and it twists off. Sometimes backing it out a bit and restarting will help (not always.)
djd99
Owosso,Michigan
I must of alway's did it the right way then, Thank god for my dewalt impact.
kbs2244
"Tapcons are that weak? Wow. "
No, a hammer drill with the clutch set to max is that powerful.
