my craftsman set
slipperier than deerguts on a doorknob when you're trying to juggle the wrench with one hand and the feeler gauge with the other and hot oil is splashing all over your forearms. fun times.
After my dad taught me how to do it, he just stood back and laughed. Mom was not amused.I can't think anyone would adjust solid tappets with the engine running. Too easy to bend the valve on a flathead or pushrod on an overhead. Proper procedure is to adjust to the low side of the cam, start engine and run until hot, shut it off and readjust to no clearance but not binding. You should be able to spin the valve without binding but with no clearance. Whoever is using a feeler gauge on flatheads is going to have a noisy engine until a valve stem bends.
Adjusted hot and running was the way we did it, when that was the spec. Never bent a pushrod. I don't know if those old engines were interference designs like a lot if the new ones.I can't think anyone would adjust solid tappets with the engine running. Too easy to bend the valve on a flathead or pushrod on an overhead. Proper procedure is to adjust to the low side of the cam, start engine and run until hot, shut it off and readjust to no clearance but not binding. You should be able to spin the valve without binding but with no clearance. Whoever is using a feeler gauge on flatheads is going to have a noisy engine until a valve stem bends.
Probably the valve springs on that little Opel weren't strong enough to damage the feeler blade. My feelers were never the same after adjusting early inline 6 cylinder motors running. Kind of a challenge to keep the screwdriver in the slot too.
I found another long C tappet wrench No 2 with the other Craftsman stuff on Friday. It's at the top of the picture.
Probably the valve springs on that little Opel weren't strong enough to damage the feeler blade. My feelers were never the same after adjusting early inline 6 cylinder motors running. Kind of a challenge to keep the screwdriver in the slot too.:eyecrazy
This.I never bent a pushrod on that Opel and never damaged a feeler gauge.
The post above is the first time I've ever heard anybody say adjusting them with the engine running was the wrong way to do it.![]()
i love these craftsman wrenches. Very extensive set. What is the part number range? I will begin a quest for the rest.
Thanks
alton1911
44470 - 44474
Milwaukee Tool & Forge, 9/16 x 5/8, very thin wrench, about 5/32.
potato said:44470 - 44474
I may be mistaken, but I believe that before those Craftsman tappet wrenches were model numbers 444XX -- 444XX, they were No. 1, No. 2, No. 3... etc.
