Tapping Threads into 1/8" Sheet Metal
mike7
Would it be possible to tap threads into a piece of 1/8" thick sheet metal? For what it's worth, the threads I need to tap are 1/4-18 NPT. So if I'm doing my math correctly, that's .125 times 18, which means there will be 2.25 threads. Is that enough for it to catch?
Fordman7795
Bay City, MI
If you are able to cut the threads it will be very weak. I doubt you will be happy with the results. Could you double up the thickness where you are tapping?
JJThrasher
Indiana
Can you tap the threads? Probably. Willn it be strong? Not really. The question is, why? What are you attempting to do with these threads?
Sent from my SCH-I535 using Tapatalk 2
1951sms
Depends on what kind of stress you will putting on it , how many holes and if it is going to be on a movable item. I've done many such projects on Coal Mining Power centers and have done well but they on a stationary object. If you are able to use the pop rivet style nut that leaves a not on the backside you wont have ANY worries.
larry_g
oregon
For a NPT thread you might get away with it if there are no loads on the thread other than the pressure. For pipe threads you might consider installing a bulkhead fitting.
lg
no neat sig line
rsanter
visalia ca
Drill a smaller hole
Use a punch to form a bit of a funnel in the metal. You will need tp support the back as ypu punch form the funnel shape.
This will give you more material to tap
Bob
sparky5982
Why not spot weld a nut to the sheet metal? I see this commonly done on thin metal paneling, such as for machine panels.
larry_g
oregon
IS ANYONE PAYING ATTENTION??? The op is wanting PIPE THREADS...
lg
no neat sig line
A lot of it depends on how much load is going to be placed on it !
Use a punch to form a bit of a funnel in the metal. You will need to support the back as you punch form the funnel shape.
Bob
Excellent idea !
For support you could use a block of wood with a hole drilled in it a bit bigger than the pipe. 1/4" pipe has an OD of 0.540, so maybe a 5/8" (0.625") spade bit for the wood block.
thinmac
Oakland
Is the fitting going to be either holding pressure or under liquid? If either of those are the case, it won't work. If there's going to be any stress on the pipe, it won't work. If it's just a place to dump in fluid, maybe. If you don't have a bulkhead fitting handy (and who does?), you can cut the threaded end off a ****** and weld that on. Don't try to weld a regular pipe fitting on, though, as they're almost always cast.
Also, never try to weld on anything that's going to be holding above atmospheric pressure. The weld needs to be perfect, and the steel needs to be properly tempered or you'll have a brittle area that can fail with very bad results.
thinmac
Oakland
Oh, another thing I've done before is take a thicker piece of material, half inch thick or so, and drill and tap that to make my own bulkhead fitting. Still, only for low pressure.
mike7
Lots of good ideas here. I appreciate the responses. The fitting will be subjected to no more than 15 PSI, so it's definitely a low pressure situation. Would a bulkhead fitting be sufficient for this application?
Big Pete
bulk head fitting is the way to go, for 15psi a water tank one would do.
Bruce Lancaster
Rsanter has it. From the bits of information given, sounds like a small brass fitting going into a tank or something...
So use that method, clean and tin the sheet (this can be largely taken care of before making the hole!) and tin the fitting. Screw'em together, heat'em up with a propane torch, and flow on a bit more solder. Should be good enough for anything short of the space shuttle. Actually, fine for that too, now that the thing doesn't move around.
