Tapping with guide?
Krokodil
South Africa
Does anyone here tap with a guide? I saw a youtube video of a guy using a tap wrench and guide in a drill press and I like the whole idea for perfect square alignment.
Then I also saw these blocks with holes for alignment that is placed on the work surface.
Anybody have a preference? Looks like I will get a tap guide for my t wrench as a start.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
A tap guide is very useful for starting your taps. I've made a dozen or so over the years and gave them to others. I always use it for starting the tap, then back the tap out, remove the guide, then proceed back to tapping. Normally with the thickness of the guide, it won't allow you to tap all of the way through a piece of material if it has any thickness to it. You can buy one, or you can make one. You want to harden it so the taps teeth doesn't wear the holes open. You also want the holes in the guide a little larger by a few thousandths so the tap is not binding up against the sides of the holes. Normally the ones that we use in the states run from 0-80 through 1/2". As far as Metric goes....I very rarely use metric taps, but the same principle applies.
bullnerd
Jersey
Like Kev said,you can make them. My favorite one is actually hard plastic. It doesnt scratch the surface.
Also have the spring loaded jobber but also have one thats basically just a point, think of a lathe dead center. Works just as good.
racingtadpole
The far side of crazy.. but sometimes Australia
I had never heard of such a beast as a tap guide... Possibly another tool on my 'thanks to Garage Journal' list. I usually start them in a drill press or lathe where possible. When thats not possible I have been known to drill and tap a piece of flat bar using the drill or lathe and then secure it to the piece I need tapped as a starter for hand held stuff.
Larwyn
Texas
Thanks Jerryd68, The EZ Tapper looks identical to the "Hand Tapper" that I got from HF, and your link has a much less cluttered picture of it. I'm sure that mine has prevented several dozen broken taps over the 10+ years that I have had it despite the clutter.
ilovevocs
Toledo, Ohio
I use one as well. I believe mine came from grizzly. I also use a spring center In the drill press or lathe. From time to time ill hold a small square against the tap and let it rip.
454ragtop
Carver, MA
Also have this set, never seen another like it. Has coarse taps and their drills on 1 side, fine on the other. Then has a master guide with a bunch of different "caps" that fit different size tap shanks, to hold them square, all in a cool cast stand.
Jim
zkling
Spring or non spring loaded tap guide is a good "learn the machines project" super handy to have around.
Quite often I will power tap in the milling machine. If your drill press runs slow enough and you find provisions to reverse it this is very fast.
A purpose built hand powered tap guide is nice like the shars ez tapper. If you want a cheap alternative. Find an old cheap bench drill press. Doesn't even need a motor, and find a way to mount a steering wheel where the pulley originally was. Super handy. 99% of the machine work is done for you already. I did something similar to this with a drill press I found in the trash.
I bought a tapping head for $5 years ago. Did not find it to be as useful as I had pictured. Especially for the price they fetch new.
spongerich
Monroe, NY
I haven't made a spring center yet, so I usually just chuck a point in the drill press or mill and hang a 10lb weight on the feed handle. That lets me use 2 hands to get the tap started while applying just enough pressure. IMO, using a guide is essential for small taps which seem much harder to start straight by hand and much more likely to break if they're misaligned.
Regnar
You could always do this. Takes a little practice but after you get the hang of it you can tap things in no time.
