Tar Removal From Concrete
Worker in Progress
Colorado Springs
Hello Friends,
I am a homeowner who is still learning how to be handy and how to do my own upkeep and home maintenance. I am new to the Forum, but I can tell you are all a wealth of information, and I look forward to hearing more from all of you.
My current issue: the City was right in front of my house doing some major street repairs and apparently one of their drivers used my driveway to backup and turn around, leaking a "V" shape of tar on my (recently replaced!) driveway. Obviously I am displeased, but there has to be a way to get this off, right? Photo attached. Tar trail is about 1/8"-3/16" thick at its thickest. Concrete is slightly textured.
I have a power washer, but not a heated one, and it seems expensive to rent for such a small area. I have read up on some corrosive/acid options, and I am open to that, but I would ask your advice on proper technique because they seem dangerous if done wrong.
Thank you in advance!
DTE
North Carolina
I would try freezing it with some ice and popping it off, solvents or heat and you will have a mess
W
Worker in Progress
Colorado Springs
DTE, I could try this on the thicker parts, but there are definitely some parts that are too thin to "pop" off; more like a layer of paint. There are thicker parts too, though, so I'm convinced it is not just oil or paint. Thank you for your feedback!
BillK
Beautiful Southern Maryland
Bill, I definitely thought about it, but my concern was they might "take care of it" in a way that was just as sloppy as how it got there, or worse.
You are probably right :( Anything petroleum related should take it off. I would scrape as much as possible with a putty knife and then pour some turpentine or cheap paint thinner on it and hit it with a stiff brush. A few times of that and rinsed off with soap and water will probably get rid of most of it. The rest will disappear in no time out in the weather.
SGKent
Citrus Heights CA
I'd hit it with some freeze spray, put dry ice on it, or liquid N to cool it and chip as much up as possible first. Use the edge of a chisel or thick bladed knife to get under the edge. don't over freeze the concrete so you don't spall it.
