Any ideas??
Oops, still have to wire in the compressor, as soon I can figure out to get if off the trailer and into the corner!Any ideas??
Looking good, Dave! Do you have, or can you borrow, a shop crane? I've unloaded any number of things from my truck by-myself with mine including the HF 13-drawer rolling cabinet and a 950 lb Snap-On mid-rise scissor lift. I know I've seen at least one other thread with an 80 gallon compressor unloaded from somebodies truck with a shop crane.
You can "walk" the compressor. Back the trailer as close to the location you want it. Then slightly tilt the compressor, just enough to take the weight off one foot, and walk it into the corner.
For the 80 gal you might want a buddy to help out.
why did you put the compressor inside the shop verses outside? seems like it would be very loud when running, mine is.
garage looks great and I really like the camaro. why did you put the compressor inside the shop verses outside? seems like it would be very loud when running, mine is.
Belt-driven aren't that loud, at least compared to oil-less. But it's still a valid question given that he's building from scratch. A dog house hanging off the back or side would have kept it out of the weather and the neighbors happy, while freeing floor space and ear space inside. Dave?
Looking good Dave. I thought I saw you over here too.
You know that you're just going to have to move all that stuff to paint now!!![]()
Thank you Dave for the pictures!!!!
I am building a 24X24 with 9' 6" ceiling. I too have a pilke of pictures. I will start a thread soon. We started pretty much the same day as you too. I built it all myself other than the concrete work. I want to start a thread sooooo bad but want all the pictures together.
sooooo sooooo glad you are posting pictures, please keep them coming
from another "local" a few provinces to the west, Alberta
Rob/HBT
The only concern I would have with the water trap you posted would be when the water collects on the first down pipe and the up pipe(the U section in the middle) it would sit in the bottom with no where to go unless the air blows it all the way up the U?
Garage is looking good.
that is a sweet cupboard!!!!!! clean it up and it will make a sweet "flammables" locker.
me too, I'm with Scott on the water trap
seeding the yard????? We are sitting at a balmy -12C with a stiff breeze and a skiff of snow on the ground and I have to go hook up my outside electrical. Then call for a rough in inspection on the electrical. brrrrrrr
Rob/HBT
I like your idea for lighting. I am going with the same sized garage and one of my "must have's" is proper lighting. My current 2 car garage has the standard 2 light bulbs so any evening or door-down work always leave me with dark zones under the car , even with portable light sources.
Are you just using a standard 3 knob light switch ? That's how I pictured doing mine, turn on only as many as I need at any one time.
They're also positioned slight forward so when the hood of the vehicle is open, it should still throw light under the hood.
Dave
Hey Dave,
I just read through your build thread and your garage looks great! Right now I have a 20x20 garage in Ottawa but for my next house I will want a garage almost exactly the same as yours. The only thing I'd do differently is either build an enclosure for the compressor, or have a small extension added during build for it.
I just painted my OSB walls white, red, black, and grey. I used Behr exterior Matt finish paint, and I found that priming is a must!! I primed before painting the white, and still needed several coats (like 4 or 5). Maybe 2 coats of primer would have helped.. I don't know.
What thickness is your OSB? I LOVE the fact that I can screw anything anywhere (you know what I mean!).
Maybe I missed it, but are you planning to cover the floors with anything?
Again, your garage looks awesome and keep the pictures coming!
Barry
People are suggesting placing the compressor outside to save space/lower noise levels. Is this really an option in a cold climate like we have in Canada ?
Dave, great minds think alikewhat I did (am doing) was 2, 8' track lights in each bay with 4 heads on each pointing under the hood. I pulled the truck in (longest vehicle) propped the hood open, got up on the step ladder and followed the line on the hood to the ceiling. This is where the tracks are mounted. The heads hang down about 6" so it will be even better.
PM me your e-mail, I'll send you some build pictures if you want
Rob/HBT![]()
I thought this garage looked familiar. I have been watching your progress on VCCA Chat II, and was going to suggest you post It on Garage Journal and here you are! I must of missed It here. Looks great, nice job.
Richard
