eclipsetim
- Joined
- May 16, 2015
- Messages
- 4
Hey my name is Tim.
To start with a fellow employee replaced a 3/4hp 220v TEFC condenser fan motor. This condenser is actually for a walk in freezer. It's horizontal mounted by belly band and the condenser has a fan shroud built on. The problem is the motor is over heating. This unit is suppose to **** air thru the condenser over the motor thereby cooling the motor. When I looked at the fan blade I noticed it is even with the outside edge of shroud. The air seems to only blow out the sides and seems to actually be causing a vacuum directly around the motor. The shell temp was 156 degrees Fahrenheit. Way to hot.!. So my question is where should the fan blade sit in the shroud for maximum air flow and proper cooling off the motor. I'm going back to the site monday to fix it.
So far I have read a half and half rules. Half in and half out. Can someone confirm this and explain the workings of said rule if so
