Tee fittings what is a INS FITTING MEAN ?
GophersGarage
Ontario Canada
Hi guys
Silly question
But I have to get a metal tee fitting
The hose I am using is 1-1/4 ID rubber hose and 3/4” ID rubber hose
So I was going to order this stainless fitting which is listed as INS
not sure what that means does that mean inside dimensions is 1-1/4
I am use to terms like ID or OD
I need a 1-1/4 OD AND 3/4” OD TEE FITTING
Kevin54
MEMBER EMERITUS
Urbana, Ohio
According to a pipe abbreviation chart...... INS Insulation – Applies to the non-metallic coverings applied to piping systems or equipment for the conservation or retention of heat or cold.
But by the way it is listed in the description, it looks like it means inches. And seeing that you are in Canada, that may be why it's listed that way instead of metric.
G
GophersGarage
Ontario Canada
Interesting thank you
I guess it’s safe to say my needs of 1-1/4” ID hose should fit that tee fitting
