Teflon on hot water tank element
Bangon61
BC
Me again. Conflicting views on this. What's the general consensus for using sealant on replacement heating element for my hot water tank. The element has a rubber o ring. Is that not enough? Thanks again for all the help
Bangon61
BC
What's the conflict you're hearing? If it has a gasket, it isn't sealing on the threads, so tape isn't required. But I will add that teflon tape makes a decent anti-seize, so I'd use it and can't think of why it would hurt.
That's actually a great idea. Thank you
mike93lx
Richmond, VA
The "issue" is insulating the anode from the tank. That said, a couple wraps of tape probably won't do that
rlitman
Long Island
The OP asked about a heating element, not an anode. But to your point, I'm not even sure it's possible to wrap so much tape around a properly tightened NPT fitting that an anode's current path would be interrupted by it. At some point, some thread crests will need to make contact for the fitting to engage, and with enough tape to prevent that, you won't even get the threads in the first turn. Besides, anodes only need to carry micro-amperes of current at the very most.
mike93lx
Richmond, VA
****. You're right, my bad
BrandonV
Arizona
Off topic. I've measured the resistance multiple times and I've never seen anything that would make me question using a thread sealant (tape or dope).
