I have a 1/4 drive composet.the direction lever can go hooky every now & then .doesn't seem to engage properly and goes into a neutral state. Sarted doing this early on.
I enjoy and recommend Tekton ratchets. I have 7 of their 90t ratchets and one of the 3/4" drive 72t ratchets. I'd argue that they are on par or better then Snap-on dual80 ratchets. The 1/4" drive ratchets are better then Snap-on comparable. I'd say the Tekton 1/4" drive is on par with Nepros 1/4", albeit the fit and finish is second to none with Nepros.
The ratcheting mechanism is really solid on these, and the back lash when the next tooth is engaged is next to none. The Snap-on dual80 1/4 drive has a lot more back lash than they should, so the Tekton and Nepros both are better in my opinion. What's the point of having a fine tooth ratchet with a low swing arc if you have to overcome the lash that nearly doubles the swing arc? Durability-wise, I've intentionally been hard ony Tekton tools expecting them to break, but I still have yet to break one. I tightened up a lug nut to 90 ft lbs with the 1/4" flex head Tekton ratchet with a cheater pipe just to see if it could match what Snap-on claims with their 1/4 ratchets, and it took it like a champ. All in all, I feel that the Tekton 90t ratchets are the best bang for the buck on the market right now.In which ways do you think they're better than Snap on (outside of price) and on par with Nepros? Also something that's never factored in is long term durability. I know Tekton makes a pretty good product but these haven't been out for long. A year or so, right? Whats long term durability like?
...Also something that's never factored in is long term durability. I know Tekton makes a pretty good product but these haven't been out for long. A year or so, right? Whats long term durability like?
Sent from my SM-G975U using The Garage Journal mobile app
Valid question I suppose. But really, long term durability? On a ratchet? When is the last time you broke a 1/4" ratchet (or any size ratchet for that matter)? Typically the anvils shear off before any other part of the ratchet fails. At any rate, given the support that Tekton has shown I have no doubt they would provide a rebuild kit or a replacement ratchet in the event one is needed.
As far as Nepros, I've never owned one but people put Nepros stuff at the top of the chain, and you're telling me Tekton's making a ratchet on par with that for 10x less?
I feel like they're a really good value too, but on par with Snap on, better than Nepros? Idk...
I wish Tekton would come out with a non offset handle 3/8 drive flex head ratchet measuring approx 13 inches long overall and a similar 1/2 drive version measuring 17-18 inches long overall.![]()
Tekton ratchets are made on Taiwan. The Asians CAN make things of high quality.
Snap-on is made in the USA, probably at Union wages. So yes, I can believe the Tekton can be similar in quality for much less. Paid $35 for Tekton half inch, fine tooth ,flex head, quick release, long handle. I took a gamble cuz Snap on cost $232.
I was comparing the Tekton ratcheting mechanism to Nepros, but if cost wasn't a factor I'd take the Nepros because the fit and finish is stellar and I enjoy the handle shape. If it were between a Snap-on and Tekton 1/4" (or even other drive sizes) I'd likely take the Tekton, but once you bring price in to the consideration Tekton wins all day.I have no doubt about Tekton being quality or the Asians making quality tools. 90% of my tool box is made in Taiwan tools. I don't know that they're better than the best, but I guess they must be, I'll have to get some more 90T stuff [emoji106]
Anyone else have info? Why would one buy Nepros when Tektons just as good?
...If it were between a Snap-on and Tekton 1/4" (or even other drive sizes) I'd likely take the Tekton, but once you bring price in to the consideration Tekton wins all day.
I don't have any experience with the 90 tooth ones, but Tekton's 72 tooth ratchets have an annoying tendency to look up. I hope they fixed this problem with the 90 tooth ratchets.
I've got a Tekton 1/2" torque wrench that you could call a "quasi-ratchet". The lock nut seized this summer after less than a year of light DIY use. I had to spray it down with Kroil and then put it on the shelf for a couple of weeks before the lock nut was free.
So yeah, "locking up" may be a pattern failure with some of Tekton's ratcheting tools.
Any idea why that happened? Did you turn the torque setting back to its lowest setting when not in use? How did you manage to spray the Kroil in, eg through the middle of the shaft or down the center of the nut at the end?
